Lifter noise after oil change - Defender Source
Old November 21st, 2009, 05:45 PM
Campbell's Avatar
Campbell
Rich Campbell
06 LR3 01DII D90s sold
After running regular oil for 130k i switched to mobil 1 10/30. Changed the filter every 500miles. I'm now getting a lot more lifter tap. Thinking about going to 0 40 or draining a quart and adding Lucas oil stabalizes. Or I might just do a oil flush product and go back to regular oil.
Any thoughts?
Old November 21st, 2009, 08:08 PM
Grover's Avatar
Grover
Question
Any thoughts?
Answering your questions with more questions:
What weight of regular oil were you running?
Why the switch, assuming you are now running synth?
Does the lifter(s) tap constantly, only under load, only at idle, only at cold startup?
Is the tapping sound coming from only one area? front and/or rear of block? PS and/or DS bank?
How is your oil pressure?
Where do babies come from?
Cheers...
Old November 21st, 2009, 09:43 PM
Campbell's Avatar
Campbell
Rich Campbell
I was running reg 10/30.
Switched to syn.
only really hear it at Idle, more at startup.
not sure what pressure is but no warning light.
Seems to be a general noise from the bay.
Babies come from somewhere around the vagina area.
Old November 21st, 2009, 10:03 PM
I would pull the pan and see if your pick up is clogged.
Old November 21st, 2009, 11:14 PM
Grover's Avatar
Grover
Check this out...
http://www.defendersource.com/forum/...30&postcount=3
Cheers...
Lifter Noise JimVT Defender Technical Discussions 5 February 28th, 2005 12:46 PM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
Oil Change Screw-up zed111 Defender Technical Discussions 9 July 19th, 2004 11:48 PM
» Defender Registry
Hyacinth
dmurrell
RAF
Realm
Add your Defender
