lifted d 90 noise - Defender Source
Old June 11th, 2005, 11:48 AM
4x4x46
Bobby
lifted d 90 noise
i have a 97 d 90 wagon lifted 2 in i have a groning noise on decel mostly around 50 sounds liek a diff noise but installed a new diff. I was wondering if anyone else has had the problem too,Seems to be from the driveshaft and the shaft is on a little bit of a bind ...Any ideas??????
Old June 11th, 2005, 12:24 PM
Lube up my man! Grease up your u-joints and spray some WD-40 on the new springs wherever they touch other metal (top & bottom). 99% chance that will solve your issues...........
Welcome to the Forum.....................
Old June 11th, 2005, 12:46 PM
4x4x46
Bobby
joints are brand new i can get the truck to make the noise on jack stands.Its really got me stumped
Old June 11th, 2005, 01:18 PM
JohnC
Giampaulo Cinquegrana
95 DI SR Extreme Kit - 94 RRC LWB
You installed a new diff where, front or back?
Did the grinding noise start after you installed the lift or after you installed the diff?
If you installed the diff in the rear are the front and rear flanges facing the same direction? How about in front?
With the new diff, did they replace the bearings? Set the backlash? Install the right shims? Spacers?
Have you tried driving with only one driveshaft to isolate the noise?
A bit more info would help.
Also, do a search on this board and you'll find that a few members have had the same problem.
Good luck.
John C.
Old June 12th, 2005, 09:55 AM
4x4x46
Bobby
noise was before and after the diff i got a entire jackpot from rover .It was a rear diff .i havent tried driving with just the front shaft because the noise is so loud at the rear ,with the rear axles out it is muh louder for some reason
Old June 13th, 2005, 08:38 AM
Check the T-case fluid, maybe even change it to make sure it is good. I would also check the fluids all around to see if there is any metal in it.
Old June 13th, 2005, 08:41 AM
4x4x46
Bobby
did that too allthe fluid was clean noise sounds like it isthe driveshaft to me even after the u joints were replaced
Old June 13th, 2005, 08:46 AM
I have replaced UJs and they went bad after 10 miles of driving because they were the wrong size. Is anyone near you that you could trade drive shafts with just to see if that is it for sure? I think Ken Loy is in Marry land, he has a 94 and I'll volunteer him
Old June 14th, 2005, 07:21 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
If he's up in the Baltimore area he might want to talk to Trevor.
Jimmy Buffett
Old June 15th, 2005, 11:37 AM
4x4x46
Bobby
trevor looked at it already
Old June 15th, 2005, 07:02 PM
redrover
Guest
Posts: n/a
Hi bobby, do a search for info on your problem. If you lifted the truck you now have some issues with a steeper drive shaft angle. You can pinpoint which one is the culpret by removing one at a time and test driving. Just pull the front drive shaft first and make sure you have the center diff lock ingaged. To search for related info on your problem input "drive shaft or double cardon drive shafts." JP
You have a couple of fix options to consider
Old June 15th, 2005, 07:29 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Yeah, jp, that's the best advice I've heard. Anyway, just to add to that, here's some good links that will help you understand what CAN happen when you lift a vehicle without doing anything else to it.
http://www.4xshaft.com/driveline101.html
and for more in depth info, check out these others here
http://www.4xshaft.com/techinfo.html
90, d 90
engine noise. Campbell Defender Technical Discussions 31 October 3rd, 2005 10:34 AM
Noise from engine--curse of my existence Davis Defender Technical Discussions 25 June 24th, 2005 04:27 PM
Curious knocking noise mikeslandrover Defender Technical Discussions 6 March 29th, 2005 06:09 PM
LT230 noise? Chaucer Misc. Chit-Chat 5 March 19th, 2005 02:59 PM
whistling noise from engine jstrong98 Defender Technical Discussions 2 December 14th, 2004 11:37 PM
