Lift question beaten to death again...... - Defender Source
Old July 6th, 2005, 12:57 PM
gonewheeln
Mark Handlovitch
Anyway I plan on putting the 2" RoverTym springs on my 94 Soft Top and the shocks that they sent with the springs are a factory replacement. I only plan on having this lift for the summer until I can afford to go all out but will these shocks work or should I get longer ones?
Mark
Old July 6th, 2005, 01:38 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
You might want to get some OME shocks. They are two inches longer than stock so they should work with those springs well. Or you might want to look at some Pro Comp shocks from Rovers North, they are also two inches longer than stock so they should work well wit those springs. They are like like $150 for the set of four normally but they are on sale for $130 now.
'97 D90 - 4.6
'00 D2
Old July 6th, 2005, 05:01 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Hey Mark - so you broke down and got a D90! I think the downsides to the stock ones would be travel (obviously) and crappy ride. When Sean G. had Bilsteins plus LR HD springs, he popped the rears out on full articulation, but just barely, so I think those would be good for now, or the OME's.
Dave
Old July 6th, 2005, 05:18 PM
gonewheeln
Mark Handlovitch
Dave
Dave,
Damn I haven't seen or heard from you guys in years..........we all thought you fell off the planet or something. How have things been?
Anyway I talked with RoverTym and thats what he said. I suppose it will work until Larry and I can get started on my custom 4-link up front and in the rear.
Mark
Old July 6th, 2005, 05:28 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I assume you are going with Y link 4 link up front?
Old July 6th, 2005, 05:38 PM
DaveHuny's Avatar
DaveHuny
Van Der Waal
none
Originally Posted by gonewheeln
Dave,
Ha! We nearly fell off, now we're in CT. When we started having babies we took a break from 4 wheeling (don't take a 7-months pregnant woman on Chinaman's Gulch in a Series truck and then with moving and all... I got rid of the Series and the RR to get the D90, but we still have the Disco (kid trolley).
Old July 6th, 2005, 06:57 PM
gonewheeln
Mark Handlovitch
Talking
Maybe if there is the room or I may just go with a standard 4 link like on a TJ, well 5 link if you count the panhard rod
Mark
Lift gate upper hinge bracket pictures / question dave_lucas Defender Technical Discussions 7 May 21st, 2009 12:07 AM
Question about 2" lift on NAS D110 Stmpede Defender Technical Discussions 10 April 3rd, 2007 06:12 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
