Lift Pump Failures? - Page 2 - Defender Source
Old August 29th, 2016, 11:10 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Photos:
On the filter the top line goes to the IP.
The bottom line on the filter goes into the top of the lift pump.
There is a hard plastic line fuel that T-s into the Webasto heater and also the lift pump. The IP has a fuel line that comes out of it.
I disconnected the solenoid and cranked it twice and got no fuel out of the bleed screw on the filter. Third time is the attached video.
I didn't disconnect the fuel line on the filter because I couldn't get the bolt loos on it or the IP and didn't want to make a mess of them. The hose is crimped in place and I don't have a replacement clamp. If I still need to get the hose off to check flow I can but it seemed pretty decent to me just with the bleed screw.
ID:	156636   Click image for larger version
ID:	156638   Click image for larger version
Old August 29th, 2016, 11:44 AM
Are you positive? As I understand the 300TDI lift pump, the inlet is the top port and the outlet the bottom port.
Although it does seem to be pumping.
See attached from the workshop manual.
Old August 29th, 2016, 11:51 AM
aosias's Avatar
aosias
Alexandra
1995 D90
You are correct. I had that written down wrong. It's set up like the diagram, just without the optional sedimenter.
Assuming I can rule out the lift pump or fuel delivery to the motor as my loss of power.
Old August 29th, 2016, 12:41 PM
Looks fine. "Maybe" a bit aerated, so a leak on the suction side might be possible. I don't think sedimentors are as important with a 300TDI as they have the screen inside the lift pump. Early engines don't have a screen and the check valve is easily messed up without a sedimentor.
300tdi lift pump pressure Surfin' Elvis Defender Technical Discussions 2 November 27th, 2013 01:53 PM
3.9 Fuel Pump Relay internittent failures djrover Defender Technical Discussions 0 September 3rd, 2013 11:47 AM
feed 200tdi lift pump from Facet fuel pump ? kjva Defender Technical Discussions 1 September 7th, 2011 12:55 AM
200tdi lift pump install tomaco1 Defender Technical Discussions 8 July 21st, 2009 01:40 PM
300Tdi Fuel Lift Pump Lyman Defender Technical Discussions 2 May 23rd, 2006 04:53 AM
