Lift kits for a D90 - poll time - Page 2 - Defender Source
View Poll Results: Which lift kit for a D90?
Old Man EMU - springs only 37 45.68%
Rovertym - Standard 2" lift - springs only 14 17.28%
Rovertym Full Flex - w/cones, rear links, shock mounts 13 16.05%
ProComp 2' Performance Suspension Kit 0 0%
Draken/Equipe Base Kit II - w/cones, rear links, shock mounts.. 4 4.94%
Other 13 16.05%
Voters: 81. You may not vote on this poll
Old April 19th, 2007, 12:55 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
I think I had RR1 RR4 combo but I could be wrong since it has been 3+ years now. The only problem I had with them is I couldn't flex them well, I could not put my 14" travel shocks or 3-link to use. They did not sag and ride quality was good. I used my 90 for trails only and they didn't do it for me, and that's why I went coil overs and OME springs.
I also think my buddy had the same set and he had to use spacers to level he 90 out, and I did also.
World traveler
Old April 20th, 2007, 07:11 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
Thanks for the input..
So it looks like Old Man EMU is the most popular - 41% so far.
Old April 22nd, 2007, 06:45 AM
scoloco's Avatar
scoloco
'94 D90 ST
I put OME on my truck. I think the 751/764 set. Empty it sits tail slightly high. Put stuff in and the back squats down. I also dont think I got the advertised 2" out of it - maybe the back empty, but not the front (my measurements showed no lift up front after putting them in). I've got a winch up front and rockware bumper, so there is a bit of weight up front to think about. Next time I'd consider RTE.
Old April 22nd, 2007, 04:23 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
I'm running Range rover HD red/Wite on the back with cones and the shock mounts dropped 2" at the back with +1" shocks. Not sure what the springs are at the front, I was given them and then had to buy some +2" shocks 'cause the standard shocks were topping out all he time. All finished off with absolutely standard open diffs so I like to keep wheels on the ground no matter how lightly loaded
Mike Hammond
Old April 24th, 2007, 09:18 PM
97Ariesblu's Avatar
97Ariesblu
kyle scheppler
1997/D-90 Station Wagon
www.safarigard.com
safarigard has made all sorts of suspension upgrades for the d-90...everyone should check it out if you have not seen...my d-90 is spec-ed out with all sorts of gismo's from this website and my beast can seriously do anything!
Old April 24th, 2007, 09:21 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
If you check their site out everything has been discontinued...
Hey I take that back... it doesn't say that anymore. Strange
Old April 25th, 2007, 12:12 PM
needsaD110's Avatar
needsaD110
Ben
97 D90 #1345
RTE springs, what ever shocks you want, and EE retainers. I currently have OME springs,rovertym shock mounts,cones, and rancho 9000's. This set-up would be alot better i think with RTE springs, but the ome's came on the truck. I have run EE ret. and they are some heavy duty products, going to use them on my trail truck
Old April 25th, 2007, 02:26 PM
ChicagoDon
Don Johnson
The SG shit blows donkey nuts. The SG springs i have seen have all been sagged to shit.
Old April 27th, 2007, 09:25 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
go with RYM springs and retainers.. I like there rear links too.. very nice..
Legend in My Own Mind.
Old April 28th, 2007, 02:26 AM
mikeslandrover
Mike Hammond
Oh and I made my own 'cones' for the back to ease the springs back into their seats
Mike Hammond
Old April 30th, 2007, 08:21 AM
pmd's Avatar
pmd
Paul Dandini
None :-(
My Rovertym Springs and EE retainers arrived - time to install..
Old April 30th, 2007, 02:14 PM
mikeslandrover
Mike Hammond
Before and after photos?
Mike Hammond
Old April 30th, 2007, 02:21 PM
cellulararrest
Chris Snyder
Agreed.
Old April 30th, 2007, 02:43 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
will do..
Old May 7th, 2007, 12:14 AM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
anyone know a good source to pick up some 1" spring spacers?
Old May 7th, 2007, 09:55 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
You can get them here.
Gary
Old May 9th, 2007, 01:47 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Rovertym springs installed, new Galv shock towers, EE retainers, OME shocks....
Next project is to clean up surface rust and then the brake lines..
Before and After
Name:	d90 w-no-Lift.jpg
ID:	9278   Click image for larger version
Name:	d90 w-2-Lift.jpg
Name:	d90 front lift.jpg
Old May 9th, 2007, 02:51 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
What springs were in it before? It looks like it is about the same height, just all new stuff and the shock towers look a lot better.
Old May 9th, 2007, 05:07 PM
pmd's Avatar
pmd
Paul Dandini
None :-(
Not sure - previous owner said it had a 2" lift - but had no info.
The truck now sits about 1 3/8" - 1 1/2" higher.
Old May 9th, 2007, 05:45 PM
are those 2" or 3" springs? how are you vibes, how much does the truck lean? I might re-assess my current suspension with some RTE springs, front and rear links.
90, d90, kit
lift kits ? jonny wrench Defender Technical Discussions 11 February 4th, 2006 05:55 PM
considering d90 toolman Misc. Chit-Chat 7 March 28th, 2005 02:36 PM
D90 Tshirts norros Misc. Chit-Chat 16 March 8th, 2005 11:05 AM
