license plate light - Defender Source
Old March 1st, 2016, 03:39 PM
CaptMidnite
Daniel Choi
94 NAS Defender 90 ST
license plate light
Trying to disassemble the light assembly and also remove from the steel mounting bracket. Is it a matter of just removing the two large flat head screws? Mine are frozen tight and I can't seem to be able to apply too much torque without destroying them. Any suggestions?
Old March 1st, 2016, 03:48 PM
CDN38's Avatar
CDN38
Scott Pelly
2000 110 TD5
An LED replacement is about $30 + a plinth for about $20 more, you'll be set for life.
There should be bolts there, not screws. Someone has $^&^! with it....
LED Number/License Plate Lamp
Old March 1st, 2016, 03:56 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
That LED looks nice. If your interested I have a MOD take off that's in good shape. It's green now but nothing that a little paint can't fix. Let me know $15.00 shipped USA.
Old March 1st, 2016, 07:20 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Really nice! Except that I wish the diodes weren't freakin' 5k+ kelvin. I hate blue light ;-(
Old March 1st, 2016, 08:55 PM
Plan B: Get a normal bulb setup and buy the preferred light color bulb on line.
Old March 3rd, 2016, 01:00 AM
BMGmotors's Avatar
BMGmotors
Baird M. Gehring
1997 D90 ST #1558
There should be nuts on the other side of the panel behind the speaker housing that the screws are screwed into. Have you tried to break them loose from there?
Old March 14th, 2016, 08:52 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
Do the license plate bulbs used BA9s? If so what wattage?
http://www.rallylights.com/catalogsearch/result/?q=ba9s
ht, license plate
Replacing License Plate Light BMGmotors Defender Technical Discussions 8 January 20th, 2015 11:28 PM
License Plate Light replacement josh-man Defender Technical Discussions 15 July 10th, 2013 01:11 PM
Series License Plate Light kzack For Sale - Parts 2 August 6th, 2012 10:57 AM
License plate light for 97 defender cafemosaic Wanted 7 February 3rd, 2012 09:31 AM
Rear License Plate Light Wiring Alex D90 Smaller Projects 2 November 2nd, 2008 11:27 PM
