LHD Heater Mounting Question - Defender Source
Old April 26th, 2010, 11:47 AM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
I'm in the middle of my LHD conversion. Mounting the heater, I ran into a question:
There are 4 small studs on the top of the heater that the mount bracket attaches to. Depending on which pair you use, the heater slides left or right on the bulkhead as the mount bracket attaches to the existing bolt holes. Trouble is, I have my wings off, so I can't tell which location is proper. All the way right looks like the blower motor will be well tucked under the wing, but too much so?
Obviously, getting it in the right location affects where I cut my bulkhead hole and the proper fitting of the inlet duct. Any insights appreciated.
Old April 26th, 2010, 11:53 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
hmmm. I will take a look when I get home.
If you want to look yourself I could bring my truck by this afternoon. I'll send you an email.
maybe someone else can chime in though.
Old April 26th, 2010, 03:39 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have never seen that before. Where was it when you got it? I will take a look for you.
Legend in My Own Mind.
heater, lhd, mount
Defender LHD E Brake Handles / Wing Heater Pipes SafariHP The Vendors Loft 1 December 15th, 2008 12:04 PM
RHD to LHD conversion question Gkase Defender Technical Discussions 14 September 14th, 2008 08:01 AM
Another heater output question GaryBaxter Defender Technical Discussions 19 January 15th, 2008 07:31 PM
ST roof rack mounting question Matt Taylor Defender Technical Discussions 8 March 9th, 2006 03:45 PM
Doh! ARB 9000i Mounting question dnewman9 Defender Technical Discussions 14 February 5th, 2004 01:11 PM
