LHD Clutch Master & Slave Replacement - Defender Source
Old December 25th, 2013, 09:30 PM
It doesn't look difficulty to do but I keep reading about taking the wing off. If I'm removing the entire peddle assembly and the nuts are captive, why does it need to come off? What can't I get to with the wing in place?
Any other gotcha's I should look out for?
Thanks.
Old December 25th, 2013, 09:50 PM
Thanks.
There's a thread somewhere on this, that I contributed to.
Answer: NO don't take the wing off. DO remove the bolts from the brake pedal tower so you can move it over, then you can get the entire clutch assembly out. Doing it this way, took me about an hour first time total...really wasnt bad at all. I spent more time reading & dreading it than I did actually doing it. Then when done, I thought "oh that's really not too bad".
But again, take the entire clutch pedal assembly out to do it...once the brake pedal assembly is pushed out of the way you'll need to just twist the clutch assembly as you remove and it'll come right out.
Old December 25th, 2013, 09:54 PM
Thanks Jason. I couldn't see the logic in removing the wing.
Old December 25th, 2013, 09:57 PM
Here's the prior thread...post #7:
http://www.defendersource.com/forum/...=Clutch+master
Old December 25th, 2013, 10:55 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
No need to remove the wing.
RDavisinVA
Old December 26th, 2013, 08:58 AM
Santiago Montenegr's Avatar
Santiago Montenegr
Santiago Montenegro
98 110 CSW 300 TDi
Thanks.
Once your pedal assembly is loose, with 99% of LHD Defs you will notice that there is no way it can come out of the car. There is simply no room. So you then will have to either take the brake booster out, or mod the firewall hole, or... you've guessed it, take the wing off.
Or you might be one of the lucky ones which have enough room to wiggle the pedal assembly out. I wouldn't bet on it. Be prepared.
Old December 26th, 2013, 09:02 AM
My experience doing this a couple of times is that if you just unbolt the brake booster and simply slide it to the side it buys you JUST enough room to get the clutch pedal assembly to twist and come out.
Old December 26th, 2013, 10:21 AM
jafir's Avatar
jafir
Jafir Elkurd
What's the best brand of parts to use? TRW? Delphi?
Old December 26th, 2013, 10:25 AM
I bought TRW from Trevor. I hope it's the preferred brand.
Old December 26th, 2013, 10:31 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Exactly. It is completely unnecessary to remove the wing.
It also helps to modify a couple of 1/2" or 13mm open end wrenches to fit the adjustment of the clutch master rod nuts. I specifically use the right length piece of wood to hold the petal down, clamp the rod in place with needle nose vice grips so it can't spin, then adjust away.
Piece of wood also comes in handy if you are bleeding by yourself to hold the petal down.
RDavisinVA
Old December 26th, 2013, 10:41 AM
Robert,
What are your thoughts on reverse bleeding with a pump oil can?
Old December 26th, 2013, 11:19 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Robert,
I think that if you verify that the clutch master will squirt fluid before you install it, conventional bleeding will work fine.
The MGA & MGB is another story.
Years ago had a cleaned out 90wt gear oil qt container with a vacuum hose stuck on the end.
Would crack the bleeder slightly and attach the hose with the 90wt container filled with brake fluid hanging on a wire higher than the clutch master. Then the next step was to loosen the line at the clutch master. The fluid would fill the slave, then the hose and line eventually dripping out of the loosened line at the clutch master. Tighten the clutch master line and fill the reservoir... a few bleeds later and good to go.
Don't see why this wouldn't work with a Land Rover if you want to bleed bottom up, but never used an oil pump can.
Key is to keep air out, so it might work if the air could escape from the top out of the loosened line at the clutch master.
RDavisinVA
Old December 26th, 2013, 11:21 AM
jafir's Avatar
jafir
Jafir Elkurd
That's what I was planning on getting, probably after the new year.
Old December 26th, 2013, 01:40 PM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
I installed a Delphi clutch MC about 16 months ago, it failed recently so I went with TRW this time. So far so good.
This last time it took only about an hour to do the job. I didn't even bother to bleed the new MC. The air worked its way out within a few miles and all is good.
Old December 26th, 2013, 04:42 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Forgot to mention that the container had a hole in the bottom which became the top when turned upside down. This let air in as the fluid filled up the clutch hydraulics. I think an oil pump can would work as long as it isn't designed to let air into the can outlet between pumps so the fluid can escape.
RDavisinVA
Old December 27th, 2013, 09:44 AM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Removing the wing will take a little more of time, but it will make your life much much easier.
- Charles Eames
Old December 29th, 2013, 10:59 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Worked in the Land Rover dealership as a mechanic back in the 70s during college summers and have had Land Rovers ever since.
Have owned Series I, II. IIA, III, 90 and 110. Have replaced numerous clutch masters and have never removed the wing. IT IS A WASTE OF TIME.
RDavisinVA
Old December 29th, 2013, 02:55 PM
Roverchef's Avatar
Roverchef
Jake K.
95 D90 SW
TRW is the way to go. I can't tell you how many Delph and other brands I've had to go back and replace the 2nd time for clients. Good luck and don't take the wing off unless you really want to see what it looks like off the truck!
Old January 8th, 2014, 10:49 PM
The TRW unit I received (brand new in box) came with jacked up threads so the hydraulic line couldn't be attached. I pulled a 26 year old factory master out and I am now going to order a new factory master from RN. Looks like TRW quality isn't there any more.
Old January 9th, 2014, 11:34 AM
meatblanket
Mike Simpson
Was there a thread adaptor involved in your install?
ac, clutch, lhd, master, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
clutch question slave or master holding pressure aka rover Defender Technical Discussions 1 April 30th, 2012 08:34 PM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
