LHD Clutch Master & Slave Replacement - Page 2 - Defender Source
Old January 9th, 2014, 11:39 AM
Yes. The original didn't fit so I ordered a new one from Trevor. He tested it on a MC that he had in his shop before he shipped it. When I got it it didn't work in the new MC but it threaded right into the old MC. My TRW MC is was obviously made on a Monday after a three day weekend. At least my 90 isn't my only vehicle.
Old January 9th, 2014, 11:44 AM
meatblanket's Avatar
meatblanket
Mike Simpson
1955 86 1986 ExMOD 110
Wow, that's some bad luck. I'm sure Trevor will exchange it for you.
Old January 9th, 2014, 11:53 AM
Trevor is the best! It's all taken care of.
Old January 15th, 2014, 08:12 PM
In, done and on the road again!
Thanks all!
Old January 15th, 2014, 09:18 PM
I don't believe you. Prove it with Pics.
-Jeff
I will tomorrow Jeff.
Do you want a pic of the installed unit?
The old unit?
A selfie of me driving down the road with a big shit eating grin?
Old January 16th, 2014, 08:38 AM
Were you able to do it without taking the wing off, and just unbolt the brake booster & move it over?
Old January 16th, 2014, 10:04 AM
Yes. Unbolted the brake booster and after quite a bit of wiggling and twisting it came out.
Old January 16th, 2014, 01:30 PM
New master.
Old January 17th, 2014, 01:52 PM
Picture of me with a shit eating grin while driving down the road for Jeff:
Old October 26th, 2014, 05:19 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Originally Posted by jafir View Post
What's the best brand of parts to use? TRW? Delphi?
Took out this morning a leaking Delphi off my truck, it was less than two years old. I'm trying TRW this time.
- Charles Eames
Old October 26th, 2014, 05:21 PM
Get a Land Rover brand.
Old October 26th, 2014, 09:22 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
The one that came with the truck was a POS also, 2 years max.
I just noticed that the Delphi is no even rebuildable.
- Charles Eames
Old October 26th, 2014, 09:40 PM
What fluid are you using? Did you replace the master and the flex hose as well? I thought the oem ones were girling.
Also is the exhaust heat shield in place.
Old October 26th, 2014, 10:44 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
I'm using Motul dot 4, it's the master I'm changing, hose and slave were changed on the last MC swap, they seem to be ok so far.
------ Follow up post added October 26th, 2014 10:50 PM ------
Heat shield is on, plus the brake cylinder is first in line and is ok, so I don't think it's a temperature issue, it's just crappy seals imo.
- Charles Eames
Old October 26th, 2014, 11:05 PM
Okay, I thought it was Girling, but it might be TRW that I used, which is Lucas.
Old October 26th, 2014, 11:15 PM
Okay. I braved the weather and looked at my truck and it is branded Girling on the master. I guess Lucas, TRW and Girling are all the same company.
Old October 26th, 2014, 11:53 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
My bet is that whatever the brand is, seals are alibaba stuff.
- Charles Eames
Old October 30th, 2014, 01:09 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Just finished changing master cylinder, I hate this particular job
Next time I'm taking the wing off, no matter what they say.
ID:	106043   Click image for larger version
- Charles Eames
ac, clutch, lhd, master, slave
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
clutch question slave or master holding pressure aka rover Defender Technical Discussions 1 April 30th, 2012 08:34 PM
Clutch Slave Master Fluid Mystery RickM Defender Technical Discussions 2 August 11th, 2010 06:19 PM
Clutch replacement difficulty? Trigger Defender Technical Discussions 3 July 25th, 2005 03:18 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
