Leveling Vehicle Stance - Defender Source
Old February 23rd, 2016, 12:42 PM
for sure, to be filed under 'there-are-bigger-fish-to-fry', but let's get it out there:
my truck is pretty level front-to-back, but not left-to-right
from the front, and measured from the ground, the bottom of front bumper on passenger RH side is 23 1/8" and 22 5/8" on driver LH side
from the passenger RH side, eyebrow measures 36 3/4" front and rear...sweet
from the driver LH side, front eyebrow measures 36 1/4" and rear eyebrow is 36"...weird, but close enough
so basically sitting 1/2" lower on the driver LH side
is this worth addressing? if so, how?
thanks!
sorry for the poor cell phone image, looks worse in person
Old February 23rd, 2016, 12:46 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
OME sells spring packers, I'd just grab some of them. If it were a 90 I'd say isolators.
Old February 23rd, 2016, 12:54 PM
Also check free length of the springs to see if swapping left and right would make it better or worse.
A 110 is heavier on the left than the right and worse if LHD.
Old February 23rd, 2016, 12:59 PM
Sounds as though the springs are on the wrong sides. Without anyone in it they are supposed to sit high on the drivers side so when you get in it it is level.
Or, just get a fat co-pilot.
thanks Zack!
i had to google that and found this - heh
http://www.defendersource.com/forum/...eft-13806.html
Old February 23rd, 2016, 01:11 PM
LuisC's Avatar
LuisC
Luis Constantin
98 Disvovery 1 LE
Expedition Exchange will sell match springs (equal length).
I'm not keen on on the lean either.
Black Rhino Lives Matter
Old February 23rd, 2016, 01:16 PM
You don't want equal springs. A LHD 110 is especially heavier on the left side and needs longer springs on the left. Engine, gearbox, battery and controls are all on the left.
Old February 23rd, 2016, 01:38 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
AFAIK the gearbox and engine are pretty much in between the rails, slightly offset and I'm guessing sort of compensated by the LT230 being dropped on the right side
Old February 23rd, 2016, 01:45 PM
fishEH's Avatar
fishEH
Brett Fritzler
94, 95, 96 D1's
1/2" puck of aluminum under the LH side spring perches. Done and not even visible.
Old February 23rd, 2016, 01:51 PM
Pretty sure it is 2" or so and the engine and gearbox weigh a lot more than the transfer case.
Old February 23rd, 2016, 02:01 PM
interesting
i have no idea where to begin - local machine shop ?
but interesting
floridians are puzzled by hockey references
Old February 23rd, 2016, 02:04 PM
The leveling shims are cheaper and easier than spring spacers unless it was something you were doing yourself from scrap.
Like I said, first check your springs. It is pretty common for them to being installed on the wrong sides by some previous owner...
Old February 23rd, 2016, 04:29 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
If you research the factory spring specifications you will find that factory made them different lengths from left to right. A static truck unloaded will sit differently than when it is loaded.
Land Rover 110
Rear self-leveling unit. ajh Defender Technical Discussions 25 September 23rd, 2015 10:59 AM
problems leveling D90 with OME Suspension mrossi Defender Technical Discussions 21 January 15th, 2012 08:54 PM
Using headlight leveling switch (AMR5875) to activate ARB compress and lockers NomaD110 Defender Technical Discussions 7 September 6th, 2011 04:01 PM
Import Defender Pricing leveling out? JohnsD90 Misc. Chit-Chat 20 July 15th, 2009 04:49 PM
Tires/Rims/Lift - Stance of D-90 97Ariesblu Misc. Chit-Chat 0 June 10th, 2007 05:40 PM
