Let's talk brakes - Page 3 - Defender Source
Old May 7th, 2015, 12:34 PM
Rufus's Avatar
Rufus
Rufus
1994 NAS D90 ST #1118
Are they genuine land rover pads?
Thats the really important bit.
they are OEM pads. Its the Allmakes Rotors that Im wondering about.
"Sometimes, there's a man. And I'm talkin' about the Dude here. Sometimes, there's a man, well, he's the man for his time and place"
D90 Yahoo Group member since 2001
Old May 7th, 2015, 12:35 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Yes they are genuine pads but aftermarket rotors.
Think I am going to go with that AB kit as well.
I just have little idea how much rotors matter in terms of quality.
Thanks for the help!
Old May 7th, 2015, 12:39 PM
Rufus's Avatar
Rufus
Rufus
I am wondering about rotors as well. Allmakes Rotors is what Im wondering about
Old May 7th, 2015, 12:52 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Doesn't matter too much. I always run aftermarket rotors with genuine pads, and they're generally Allmakes rotors.
Old May 7th, 2015, 12:56 PM
Is that because "ProLine" rotors come in an Allmakes box?
Old May 7th, 2015, 12:59 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Ehhh, it's more like Allmakes rotors come with Proline labels
Old May 7th, 2015, 01:15 PM
OEM <> Genuine
I wouldn't worry about the rotors ... I'd want to see the pads from a land rover box.
Old May 7th, 2015, 01:22 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Awesome. Thanks for the advice.
Gonna go for that kit then I think.
Old May 21st, 2015, 12:27 PM
MattC
Matt Creelman
Defender Pick up 1992
If I could jump in with my brake saga, maybe you all can help. I raised the driver side of my 92 defender pick up, both front and back. I spin the tires and my daughter brakes. With one pump of the pedal the front brakes and the back keeps spinning. With a double pump of the pedal both front and back brake. This is interesting to for me to know, because on a long hill, if I dont push the pedal twice, I am probably just engaging my front disks. This is true with the motor on and the motor off.
Is this unusual? How can I fix it? Also, I just became a member of the forum. If this is out of line for me to jump in on Tyler´s thread, let me know. MattC
Old May 21st, 2015, 12:32 PM
You need to adjust the drums. They have manual adjusters. When not adjusted properly, they back off and you need a bunch of pedal travel to get them to do anything. This is something that is meant to be performed regularly.
Old May 21st, 2015, 01:22 PM
the rover shop
shayne young
With the wheels off the ground spin them while adjusting the adjusters until they drag, then back off one notch..good to go..
Old May 21st, 2015, 03:36 PM
350rangerover
3
do u guys know if the rotors on a 1974 rrc are the same for a 1987-1995? was at the auto parts store and their system dosent go that far back.
any thoughts????
Old May 21st, 2015, 06:43 PM
MattC
Matt Creelman
Thanks you both for the adjustment advice. That seems to have been the problem. Took a few turns before the wheel began dragging. Backed it off a bit. should be fine.
Old June 1st, 2015, 10:22 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
Okay fellas I have finally completed this project that started with new pads and rotors and spread to all new steering ball joints, swivel ball reseal, and ARB repair in the front diff. Crazy frustrating project.
I am not even more frustrated as there does not seem to be any improvement in the brakes. So now what?
I have new genuine pads all around with new rotors. All calipers seem to be working properly, no frozen piston and no leaks. Bled the system and changed out the fluid. I have a great pedal with engine not running. Seems to lock up all four wheels just fine. Turn on engine and pedal drops about 1/4 inch but pedal seems more spongy than before. However, the rear calipers did not move as freely as they do now so pedal could have been due to rear calipers not working properly. Anyway, what the hell should I look at next? I am leaning toward a bad booster. The pedal feels pretty good but again the system just seems weak. Like not enough pressure in the system to properly squeeze those brakes.
I can not lock them up or even come to a screeching halt even going 30 MPH. Could not lock them on gravel either. Something is still wrong no doubt.
Any ideas?
Thanks!
Old June 1st, 2015, 10:25 PM
Air.
Old June 1st, 2015, 10:30 PM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Originally Posted by o2batsea View Post
Air.
Yep… Or gunk in the front portion of the system…
But most likely air in-line.
Old June 1st, 2015, 11:05 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
I bled them 4 times and all fluid no air at all corners. Flex lines are 2 year old stainless.
Old June 1st, 2015, 11:12 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Did you put vacuum on the PS booster & see if it held for at least 5 minutes ?
Mine was leaking air through a hair-line crack near the mounting bolt head, there are 4. I repaired it by putting silicon seal over the crack, sucked some vacuum with my Mitymite, released the vacuum & let it cure for 24 hours. Tested again with vacuum & it's held since.
There are other sources of vacuum loose here too, the hoses, the one way valve, one way valve gasket, the internal diaphragm is torn.
Old June 1st, 2015, 11:16 PM
Tyler Wirken
Tyler Wirken
1997 Defender 90 LE
That was next on the list Viton. Can you describe how your brakes were acting during the leak? Thanks! But yeah up next is getting the mityvac on the booster.
Old June 1st, 2015, 11:25 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
I used a couple of reducers & a tight hose on the 1 way vacuum valve as i wanted to test the booster & valve only, not the hose.
My brake peddle was soft & won't not lock-up. Pumping the peddle, even if only twice, didn't help.
Since there is not "vacuum reserve" except in the booster, pumping won't help.
brake
Let's talk about wenches,...I mean winches Reese_D90 Misc. Chit-Chat 6 October 5th, 2012 12:35 PM
Formula R1X Disc Brakes - Mountain Bike Brakes bjf The Flea Market 4 May 14th, 2012 10:07 AM
Let it snow, let it snow, let it snow Davis Misc. Chit-Chat 80 March 13th, 2007 05:32 PM
Talk me Down- D90 vs Sportsmobile? lactic Misc. Chit-Chat 22 February 25th, 2007 09:50 AM
Talk about departing from your heritage. JBurt Misc. Chit-Chat 10 February 17th, 2006 07:25 PM
