Lets talk about HOT seatbox solutions - Page 3 - Defender Source
Old July 6th, 2016, 02:33 PM
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Originally Posted by DPdotCOM View Post
Yeah, did Jason do the same? Just trying to figure out if it'd hold up to the elements, if so, gonna buy same-day amazon right now!
Originally Posted by javelinadave View Post
Jason stuck the insulation on the inside and then covered it with an Exmoor mat. I have some radio equipment in my seatbox that needs to be kept from overheating so it needs to be insulated from the underside.
Yes. What Dave said.
I'm not sure the Dynamat-type material would hold up to the elements if installed on the underside of the vehicle. I don't know for sure though.
Some of the jeepers here in Idaho get the underside of their jeeps Rhinolined to insulate against heat and noise.
Old July 6th, 2016, 03:31 PM
hcdmueller
Chris Mueller
88 D-90
Dave,
I went with cheaper insulation on my seat box, front bulkhead and roof. Everything is great until the temp gets over 95ish. I have an exmoor mat system in my truck too.
The problem is long trips. Heat soak takes over after a while and the front mat turns into a frying pan. I need to redo the exterior insulation with some top of the line stuff and hopefully be more comfortable when the outside temps go over 100. I even have a pretty good AC setup running now and after a while it is just overwhelmed because of the lack of insulation.
Old July 7th, 2016, 12:18 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Sorry if this is off topic but it's sort of related. What do you do about the holes on the seatbox before adding this insulation? I have a 3 inch hole on the under side of my passenger seat box (????) and various other 1 inch or smaller holes that allow passage of air and water. Do you plug them up before covering with insulation or dynamat? Or do you just put lining over it and forget about them?
Old July 7th, 2016, 12:19 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
I'm going to start by covering with this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old July 7th, 2016, 12:35 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I'm interested in the stuff that javelinadave is talking about. I'd rather put something on the underside of the truck, possibly the inside of the seat box. I have new floor boards and such and don't want to put a bunch of crap all over them.
Old July 7th, 2016, 10:03 PM
There are plenty of aluminized heat barriers out there Thermo-Tec : Adhesive Backed Heat Barrier
So Lets Talk Differential Lockers Dogpilot Defender Technical Discussions 39 January 27th, 2014 04:31 PM
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Lets See those X-mas lights!!!!! Flagg Misc. Chit-Chat 15 December 19th, 2007 09:44 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
Lets mess with picture pirates! chrisvonc Misc. Chit-Chat 19 May 3rd, 2006 09:54 PM
