Lets talk about HOT seatbox solutions - Page 2 - Defender Source
Old May 24th, 2016, 10:13 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
Stick this or something similar on the stainless plates or under carriage. It will reflect the heat back. I used to use this on race car builds frequently. It works great. The gold stuff is a little pricey, I think they have a silver one that doesn't work quite as good but is cheaper.
https://www.designengineering.com/ca...r/reflect-gold
Old May 24th, 2016, 10:19 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
^^ That looks good Adam. ^^
Now we're talking good stuff.
Reminds me of this...
Rent my
Old May 24th, 2016, 10:56 AM
LR Max
Thomason, Max
1973 Series 3 109
I put down a coat of Al's heat and noise reducer in my 109. Made a huge difference in noise and heat. In low range, it knocked the noise off the transfer case significantly.
Before when I wore pants, my legs would be sweating. Now it's a lot more pleasant.
Its cheap on Amazon. If anyone is rebuilding and painting a truck, I see no reason not to put a coat of this stuff down before paint. Makes a big difference for the buck. I bought mine off amazon, so, free shipping ftw. A spray gun would have been nicer but I hollered it in.
Old May 24th, 2016, 11:33 AM
AdamSanta85
91' D90 200TDI
I could be wrong, but I was told that foil is trickle down tech from NASA
Old May 28th, 2016, 03:17 PM
Found a roll of exhaust wrap in the misc parts box and installed it on the tubing under the seatbox. While laying underneath and surveying the situation I'm also suspicious of the amount of heat transfer from the xfer case to the seatbox. Let see if the wrap helps.
Old July 5th, 2016, 05:07 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
1983 Defender 3 Door
Has anyone determined here what the best material would be to put on the underside of the seat box, specifically the areas that would absorb heat from the transfer case and exhaust? Presumably need something that's fairly water resistant/repellant down there, right?
Seafoam Green 1983 110 3 Door - sometimes SW, current ST.
Spent it's working years in France, it's mid-life crisis in The Hamptons, and now its golden years in Washington, D.C.
Old July 6th, 2016, 01:01 AM
make sure your panels are tight (under the cubby) - mine were gapped and so i had a huge influx of hot tranny air coming in.. i fixed that and its good (plus adding the exmoor matting) - wrap the exhaust but its the cats that need it
95' D90 - daily driver..
Old July 6th, 2016, 02:06 AM
Thinking about using this stuff under the transmission tunnel and seat box. Anybody have any experience with this it or something like it?
Old July 6th, 2016, 09:39 AM
maybe dynomat and then use that stuff over it as an added layer?
just throwing out ideas.
jrose609's Avatar
jrose609
Jason Rose
1983 110 County 200tdi
Dave, the stuff you saw on my rig is the same stuff. I had a roll of it and used it on the front floor boards and the top of the seat box. It works well.
Old July 6th, 2016, 09:45 AM
AdamSanta85
91' D90 200TDI
Yes. Not nearly as good as the stuff I suggested, but better then nothing.
Old July 6th, 2016, 11:34 AM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Are we talking about putting stuff on the underside of the car and seat box or in the interior?
Old July 6th, 2016, 11:47 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
underside of the truck
------ Follow up post added July 6th, 2016 11:49 AM ------
You used it on the inside of the truck, not on the underside, right?
Old July 6th, 2016, 11:53 AM
Underside not inside the truck. I'm trying not to tile the floor.
Old July 6th, 2016, 11:55 AM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Yeah, did Jason do the same? Just trying to figure out if it'd hold up to the elements, if so, gonna buy same-day amazon right now!
Old July 6th, 2016, 12:07 PM
lmwong's Avatar
lmwong
Lincoln Wong
Defender 110
Link to Reflect-a-gold on Amazon if anyone interested. I'm going to order some.
DEI 010396 Reflect-A-GOLD 2" x 15' Tape Roll https://www.amazon.com/dp/B0039Z5TYU..._oXsFxb0WFXF92
Old July 6th, 2016, 12:09 PM
DPdotCOM's Avatar
DPdotCOM
Dan Pollock
Saw that stuff, it's interesting. I'd love to combine some eat reflection with at least a little sound deadening by using some sort of thicker material.
Old July 6th, 2016, 12:13 PM
Jason stuck the insulation on the inside and then covered it with an Exmoor mat. I have some radio equipment in my seatbox that needs to be kept from overheating so it needs to be insulated from the underside.
Old July 6th, 2016, 12:40 PM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
I've been looking at roof stick-on insulation from Home Depot.
A friend put them on the inside of car and works well. In fact, most of the positive reviews on Home Depot for this product are for use in insulating in cars.
E/O 12 in. x 15 ft. Self-Stick Foam/Foil Duct Insulation-FV516 - The Home Depot
$20 for a 1'x15' roll.
Old July 6th, 2016, 12:42 PM
Naplm00
Matthew
I've used this but on the interior of a car, not sure how. It would hold up underneath one. Also gets kinda sticky when hot
So Lets Talk Differential Lockers Dogpilot Defender Technical Discussions 39 January 27th, 2014 04:31 PM
LED's installs - Lets see 'em JimC Defender Technical Discussions 73 August 30th, 2012 12:05 AM
Lets See those X-mas lights!!!!! Flagg Misc. Chit-Chat 15 December 19th, 2007 09:44 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
Lets mess with picture pirates! chrisvonc Misc. Chit-Chat 19 May 3rd, 2006 09:54 PM
