Lesson Learned - Defender Source
Old June 18th, 2012, 10:58 PM
hunterjah's Avatar
hunterjah
Jesse Hardin
Past: '97 D90 LE #135
Lesson Learned
I learned a good lesson tonight. When you go to park, notice quickly whether or not there's massive oil spot already on the ground at your parking spot BEFORE you park. Upon returning from Whole Foods, I noticed a huge oil spot underneath my LE. Haven't seen any new leaks on my driveway, so I think it wasn't mine!
Current Stable:
2016 BMW M3 (Mineral Grey)
2013 Ford Raptor (Tuxedo Black)
Previous Rovers:
1997 LR D90 LE - #135
1997 LR D90 ST - #1185 (BRG)
2000 LR Discovery SII (Oxford Blue)
2008 LR LR3 HSE (Alaska White)
2012 LR LR4 Lux (Fuji White)
Old June 18th, 2012, 11:00 PM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
When they stop leaking it's time to filler-up
Old June 19th, 2012, 05:11 PM
discotdi
Todd Miller
Land Rover
never look under your Defender, only bad things can happen.
Old June 19th, 2012, 05:46 PM
texrover's Avatar
texrover
Jason
I'm sure it was your Rover, but don't be concerned
It was just taking a dump on the whole foods earthies
Which WF do you go to? I go to Lemmon store myself
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old June 19th, 2012, 05:55 PM
petminded's Avatar
petminded
David
1995 Defender 90- Yellow- Soft Top
Made the mistake of crawing under my D90 wkend. Got scared and had to run away. Ended up changing the spark plugs hoping this would appease the D90 gods the next day. Go figure.
Lessons learned (the hard way) tomaco1 Defender Technical Discussions 4 June 22nd, 2011 07:36 AM
Learned the hard way, don't buy a fancy new car.... Hans Misc. Chit-Chat 13 September 23rd, 2010 09:01 AM
Defender glass choices-lessons learned Overlander Defender Technical Discussions 1 May 14th, 2010 10:51 PM
cross-post: Things I learned (or was reminded of) in Moab: bharris Trips, Trails and Events 7 November 21st, 2009 09:44 AM
Where did you put your ECU jcasteel Defender Technical Discussions 6 January 12th, 2005 11:31 AM
