Length of upper speedo cable? - Defender Source
Old October 3rd, 2013, 12:10 PM
dsh12
Daniel Hayes
1994 Defender 90 Soft Top
What is the length of the upper speedo cable?
Dan
94D90 NAS 3.9 LT77 LT230T Soft Top
There are no guarantees expressed or implied of the accuracy or correctness of the contents of this message, and the Author is not liable for the taking of any action in reliance upon the contents of this message. As always, do your own research. To the extent that opinions are expressed in this message, they are not necessarily the opinions of the Author.
Old October 4th, 2013, 06:45 AM
Mpfish82's Avatar
Mpfish82
'94 AA Yellow D-90 #690
The one I have that was just pulled out of my '94 is 60".
Old October 4th, 2013, 03:56 PM
dsh12
Daniel Hayes
Is it trashed? What are you doing with it?
Dan
Old October 4th, 2013, 07:20 PM
Mpfish82's Avatar
Mpfish82
It's broke, made typical mistake of pulling to hard on the speedo when replacing some plastic.
Old October 5th, 2013, 02:20 PM
Green Blood's Avatar
Green Blood
Carl Phillips
1988 90- Swiss LHD 2.5 Petrol
If the plastic fitting that connects to the speedo broke, all may not be lost. I've had two that were broken in the middle - about halfway between the cable end and the speedo end (sorry, hard to describe)- and was able to repair them. I mad a 'splint' of sorts by cutting a short section of rubber hose so that I could slip it over the fitting and then put two hose clamps around it to hold everything in place. Worked like a charm in both cases.
Somewhere I have a photo and will share it I can find it.
Cheers,
CARL
Proud restorer and former owner of '94 NAS D90 #590- back in the hands of its original owners.
And now happy owner of a 1988 Swiss-Market D90 Station Wagon.
Old October 7th, 2013, 11:14 AM
dsh12
Daniel Hayes
Pics?
Any chance you could take some pics of the speedo cable (one overall and a close up of each end --connectors) and post them to this thread. It would be a helpful as they no longer sell the upper speedo cable and it has to be custom fabricated.
Dan
Old October 7th, 2013, 11:19 AM
Mpfish82's Avatar
Mpfish82
No problem, I will take a picture this evening and post it.
Old October 8th, 2013, 05:40 PM
Mpfish82's Avatar
Mpfish82
Here are the pics of Temne cable.
ID:	81764   Click image for larger version
Old October 10th, 2013, 09:46 PM
dsh12
Daniel Hayes
Pic of other fitting?
I forgot,
Could you take a pic of the other fitting too? I'm assuming it is still attached to the housing. If you placed a ruler or a measuring tape beside it for comparison it would be helpful to the fabricators - a picture is worth a thousand words!
Thanks again,
Dan
Old October 23rd, 2013, 12:13 AM
dsh12
Daniel Hayes
The "squares" dimensions
Mike, do you know the dimensions of the squares - the (two) square ends of the
cable that you are holding in the pics? I've been told it should be either .104" or .124".
Dan
speedo
Upper Speedo Cable dimcon Wanted 3 May 25th, 2011 08:55 PM
upper speedo cable PRC9555G ini88 For Sale - Parts 1 December 21st, 2010 03:59 PM
removing upper speedo cable kolvedic Defender Technical Discussions 2 May 2nd, 2010 02:49 PM
Replacing upper speedo cable '94 wcampbel@nas.edu Defender Technical Discussions 4 December 11th, 2008 02:41 PM
speedo cable scoloco Defender Technical Discussions 7 November 3rd, 2005 07:54 AM
