Left turn signal - Defender Source
Old February 22nd, 2007, 07:55 PM
Defender13's Avatar
Defender13
Mike Lynch
1994 Defender 90 #1017
Left turn signal
I went to go change my left turn signal bulb on the fender and one of the screws will not come out. It just keeps turning. What the best way for me to get this screw out?
Mike Lynch
Old February 22nd, 2007, 08:00 PM
trislerjw
JT
97 D-90 ST
I grabbed a small piece of flat metal and pushed it against the back of the screw while screwing it out.. it took some odd positioning reaching around and screwing at the same time. (perverts)
Old February 22nd, 2007, 08:01 PM
It threads into a rivnut and the rivnut has probably let go. Get in behind it and gently grab the rivnut with vicegrips so that you can turn the screw.
Old February 22nd, 2007, 08:03 PM
Defender13's Avatar
Defender13
Mike Lynch
How do I get to the back of the screw? It seems that it is between the fender and the engine compartment/wheel well.
Thanks for the help
Mike Lynch
Old February 22nd, 2007, 08:05 PM
trislerjw
JT
97 D-90 ST
can you get the bezel off a bit to reach your hand in?
Old February 22nd, 2007, 08:11 PM
Defender13's Avatar
Defender13
Mike Lynch
I think I know what you are talking about...Do you mean to take the one screw out that I can and try to actually turn the signal up or down to access the hole. Are your thinking the signal by the headlight? That one is ok, it's the one on the side of the fender, it's sqare that I have having a problem with.
Mike Lynch
Old February 22nd, 2007, 08:16 PM
trislerjw
JT
97 D-90 ST
well then this will be easier then. Take off the front stuff (i know long) but you will spend 20 min to get your hand where the headlight hole is (and was) and can reach in the fender area to be able to get to all of that. (kindof 1/2 hr job,) but I am only 5"8" and have scrawny forearms so i could get to it ok.
Old February 22nd, 2007, 08:24 PM
Defender13's Avatar
Defender13
Mike Lynch
Ok I got it now. Thanks alot
Mike Lynch
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 10:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 10:33 AM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 10:18 AM
Turn Signal probs mspell Defender Technical Discussions 7 November 5th, 2004 05:19 PM
