left pull when braking - Defender Source
Old November 24th, 2003, 12:04 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Unhappy left pull when braking
Just noticed a strong left pull when braking. I really feel it with braking above 40mph, much less when slower. Tires are correct pressure, can see nothing on the underside or around wheel well, and hit nothing (oh, and I am ashamed to add, no off road time so that is not a cause). I am less than 3k miles since last major service. Any ideas on what to look for?
Old November 24th, 2003, 12:42 PM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Alignment or maybe bad brake pads possibly.
Chris von C
[/size]
Old November 24th, 2003, 12:50 PM
paulb's Avatar
paulb
Paul / Boultbee
I was thinking brake pads, but could not see anything. NOW, do not laugh but - we are a car short right now and my wife has been using the D-90 for to/from work travel. Round trip 15 miles, highway, no I mean freeway (CA now), travel and swears nothing weird has happened (no potholes, swerves, curbs, etc). Still do not have a repair shop here to take it to... and even tried to follow a red 96/97 hrdtop D-90 to ask where they go. Was on my mtb and lost him. Every light was against me, and my legs too!
I'm contemplating thinking about thinking about it!
Old November 24th, 2003, 01:54 PM
Siezed caliper fix NOW
if it starts to stick, brakes heat up, fluid boils = NO BRAKES
Ron
Old November 24th, 2003, 02:01 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I would bet on a sticking caliper also..
RAndy
Legend in My Own Mind.
Old November 24th, 2003, 02:48 PM
If it were a sticking caliper, would it also pull to the left when you are not braking? Unless the caliper on one side just did not grab as good as the caliper on the other side because it is dirty?
Also I had a wheel bearing seal go bad in the rear and the grease coated the brake discs causing the pads to wear down to nothing in no time. If this happened in the front I think you would experience what is happening to you (pulling to one side during braking).
Old November 24th, 2003, 03:56 PM
Chris Cox's Avatar
Chris Cox
Chris Cox
94 D90 SW, 300tdi
Make sure your brake hose(s) on the right side haven't collapsed.
Old November 24th, 2003, 04:42 PM
paulb's Avatar
paulb
Paul / Boultbee
Jesus, I go out to take a short mtb ride, come back 2 hrs later, log on and get collapsed brakes and siezed caliper. Off to the LR dealer we go. Let y'all know the verdict. Now down down to 1 car.
Good side - it is great to have such a resource to turn to.
Thanks all , Paul
Old November 25th, 2003, 08:01 AM
The way it usually goes is one caliper the pistons sieze (usually both pistons on a given side of a caliper) and don't move---ergo no brakes on that side, then they free themselves up a bit and end up siezed but with a slight amount of pressure that side, that builds heat, fluid boils and no brakes.
Ron
Old November 25th, 2003, 12:11 PM
paulb's Avatar
paulb
Paul / Boultbee
All,
Thanks to all. Still do not have a repair shop, so have the earliest repair appointment at Thousand Oaks L.R. dealership- Tuesday next week. There goes the idea of fun over the long weekend. Post repairs I will let all know what was diagnosed.
Old November 25th, 2003, 02:03 PM
Doug's Avatar
Doug
Doug Walker
TVR5L-powered NAS D-110
Did you ever call British Pacific and ask them for a referral to a mechanic in your area?
Doug
Old November 25th, 2003, 03:11 PM
paulb's Avatar
paulb
Paul / Boultbee
Yes, everything was LA and south.
Old November 25th, 2003, 05:00 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
My money would be on a stuck piston, rebuilt all the calipers on the 90 last summer, pistons, seals, pads & discs. The improvement was amazing, stopped on the proverbial six pence.
Mike Hammond
Old November 26th, 2003, 12:43 AM
paulb's Avatar
paulb
Paul / Boultbee
And Mike, that ran about how much $$ ?
Old December 1st, 2003, 05:30 PM
mikeslandrover
Mike Hammond
50 for each pair of discs.
100 for the pistons and seals
40 for the pads
stopping smartly - priceless
Mike Hammond
Old November 7th, 2017, 05:42 PM
Billykhunkhun
Billy
1991, Defender 110 EX MOD
I have the same issue and IM going to check all of these symptoms, great to see all the SoCal defenders here. Does anyone go to the meet ups
Old November 7th, 2017, 07:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Brake work this past weekend:
Was checking the rear pads that were down to 1/16".
Rear pads were replaced without issue.
The front caliper pistons were rusted and wouldn't retract to make room for the new pads.
Since this vehicle had vented rotors, had to remove the pistons from calipers for non-vented rotors and install them into the front calipers.
Reassembled and the brakes are all good.
Glad we had the calipers for the non-vented rotors in the shop.
I am going to look for some stainless pistons.
RDavisinVA
Old November 7th, 2017, 09:01 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
I have a pair of used original NAS calipers if anyone wants to rebuild and avoid the downtime.
Old November 7th, 2017, 09:03 PM
wow-14 yr od thread bump
Old November 7th, 2017, 09:21 PM
1of40's Avatar
1of40
1of40
Got to admire the same shit different decade.
front end 'clunk' when braking.. jaherring Defender Technical Discussions 3 September 29th, 2005 12:04 PM
Caliper (left DriverSide) RoverChic For Sale - Parts 5 January 14th, 2005 11:44 PM
Hitch/ pull point install question JKM Defender Technical Discussions 3 May 18th, 2004 08:39 AM
Need Left Wing outer shell vnrover Wanted 8 April 8th, 2004 12:56 PM
