Left brake lights work....the right and door brake lights won't? - Defender Source
Old June 27th, 2009, 01:11 AM
beko35
Gilbert
1997 D90 SW #158/300
Where should i start? they were just working a couple of days ago? Need your help again guys....Thanks!
Old June 27th, 2009, 01:52 AM
Check the bulbs first.
Old June 27th, 2009, 02:22 AM
beko35
Gilbert
Bulbs are good, sorry forgot to post earlier.
Old June 27th, 2009, 03:08 AM
Ok, well then you are stuck tracing wires.
Take off the lower light and see if the bulb holder and/or wires are corroded. There is a harness repair kit sold by Atlantic British or Roversnorth (I have one of each and, although the AB is not genuine, it is nicer) and you can buy the bulb holder as well. The wires and holder commonly corrode. However, since it is both and the third brake light connects behind the rear speaker on the passenger side I might look there first (it is more work) to see if the wiring became dislogded or cut etc. since it the two lights are on the same circuit. It is also possible that it is the ground in the same location.
PS I assume you have checked the fuses although, I am fairly sure all the brake lights are on the same one.
edit: it has occured to me that since you said door, you have a station wagon not a softtop and I wrote this with a softtop in mind and I am not 100% sure the wiring is the same as a softtop, but I assume it is similar.
Old June 27th, 2009, 02:12 PM
beko35
Gilbert
thanks for all the help Ron. I'll try it out.
brake, door, ht, lights
