LED Turn Signals - Defender Source
Old October 13th, 2013, 07:22 PM
brettm's Avatar
brettm
Brett
97 D90-SW, Arles +4.6
LED Turn Signals
Replaced my turn signal bulbs with LED ones (1156-A24-WV) and I swear that the blinking noise/light on the dashboard is a lot more rapid than it used to be. Am I imaging it or is some kind of lower-resistance in the bulbs affecting the circuit? I notice in the "official LED light kit" replacement there is a relay that needs to be replaced also.
Old October 13th, 2013, 07:34 PM
BlackField's Avatar
BlackField
Oscar
D110
LEDs tend to do that. Either need inline resistors or a flasher module designed for LED use.
https://www.google.com/#q=led+flasher+module&safe=off
https://www.google.com/#q=led+inline+resistor&safe=off
Old October 13th, 2013, 07:38 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yes the LED lights draw way less current so the standard flasher is very fast compared to standard filament "old school" bulbs. You can order an adjustable relay or install a potentiometer to reduce the current. If you have the trailer flasher warning bulb, you'll want to adjust until the trailer bulb flashes consistently and then "back it off" until the trailer light goes out (on the second and all subsequent flashes).
RDavisinVA
Old October 13th, 2013, 07:43 PM
BlackField's Avatar
BlackField
Oscar
D110
I havent seen the potentiometer version. Where does it get wired in?
Old October 13th, 2013, 08:03 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
I ordered a full kit with all the lights and the adjustable flasher unit. Will take a picture of it tomorrow and post.
Would think the potentiometer would go in the power wire (green circuit) to reduce voltage and slow down the number of flashes. Since the LRD lights use less current they should not display any noticeable dimness when operating with reduced current.
Have also seen where resistors are used on the output side, but am not familiar with exactly which resistor would suffice.
RDavisinVA
Old October 14th, 2013, 01:09 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Pictures of relay
Here are some pictures of the relay with potentiometer.
Could have been better, but it will give you a visual.
Here's where to buy one:
http://www.ebay.com/itm/RDX-4-Pin-Fl...item53f96434a2
ID:	82080   Click image for larger version
RDavisinVA
Old October 14th, 2013, 01:30 PM
That seems crazy expensive to me
Old October 14th, 2013, 01:40 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Yep like $50, perhaps more with shipping.
I am going to discuss this with the company that builds adjustable glow plug controllers for me (we use them on the OM617 Mercedes conversions) and see if they can build something cheaper.
Problem is you need to buy a qty for a special build and it gets expensive.
Just called Rovers North and they have an adjustable flasher relay for $23 + shipping.
RDavisinVA
Old October 14th, 2013, 03:31 PM
The alternative is to just buy a cheap LED compatible 4-pin flasher. I use one I bought from Autozone, and it works perfectly with my RDX signals.
Old October 14th, 2013, 04:16 PM
$13-15 seems to be all you need to spend.
Old October 14th, 2013, 05:13 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Superbrightleds also has them. http://www.superbrightleds.com/cat/f...oad-resistors/
Old October 14th, 2013, 05:24 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Originally Posted by Manimal View Post
That is a 3 prong... we need a 4 prong for the 90 & 110.
RDavisinVA
Old October 14th, 2013, 05:28 PM
...to maintain trailer functionality (for NAS trucks at least). Not sure what else the 4th prong achieves.
Old October 24th, 2013, 09:28 AM
Problem solved at a third of the price if the unit you listed from Ebay. Looks like same unit, different name
http://www.paddockspares.com/adjusta...her-relay.html
signal
turn signals and flashers not working draaronr Defender Technical Discussions 4 April 27th, 2008 10:19 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
Relocating Turn Signals Doug_Paoletti Defender Technical Discussions 13 July 26th, 2005 11:49 AM
» Defender Registry
D90
NPT90
Kickler
Kickler
Add your Defender
