LED turn signal head scratcher - Page 3 - Defender Source
Old June 12th, 2016, 02:39 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Thanks.
Weldon
Old August 24th, 2016, 11:14 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
This is the most confusing thread ever in the history of D90 Source.
Sent from my SAMSUNG-SM-N920A using Tapatalk
Old August 24th, 2016, 11:40 PM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'93 NAS110 #436
Originally Posted by crown14 View Post
This is the most confusing thread ever in the history of D90 Source. Sent from my SAMSUNG-SM-N920A using Tapatalk
You revived a 2 month old thread just for that nugget of wisdom?
Semper Fi!
Old August 25th, 2016, 05:40 AM
AdamSanta85's Avatar
AdamSanta85
91' D90 200TDI
You need to use an adjustable flasher relay. If you still have a double blink after relay, install a dash indicator bulb with an external ground wire. You don't need resistors. I had the double blink until I installed the new dash bulb. BoltOnBits carries the dash indicator bulb.
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 09:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 09:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 10:02 AM
Turn signal dfscott Defender Technical Discussions 5 November 28th, 2005 08:54 PM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 09:18 AM
