LED turn signal head scratcher - Page 2 - Defender Source
Old March 18th, 2014, 09:43 AM
snowpup's Avatar
snowpup
Jeff Snow
1997 D90
yep. one for each corner.
Old May 3rd, 2016, 03:52 PM
LakeLBJ
CC
SOLD - 1987 D90 LHD / 200TDI
Sorry to resurrect an old thread but I have the exact issue with my LED turn signals. Dim blink in the opposite side signal.
Should I get the resistors or the adjustable flasher unit?
Old May 3rd, 2016, 04:32 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
I had the exact same problem when I converted both front and rear turn signals to LED. The fix is to either leave the front or rear with incandescent bulbs or install the load balancers. Worked great once I added the load balancers.
Angus
Old May 3rd, 2016, 04:39 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Resisters on each front unit and you will be fine...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old May 8th, 2016, 02:54 PM
LakeLBJ
CC
I was about to head to the auto parts store and pick up an EP26 LED relay but when I popped open the fuse panel I noticed the previous owner already installed a Wipac WFL7LED. So I guess the relay is not the problem. I'm only getting the both sides flash when I turn on the left signal. If I hit the right turn signal, it functions properly.
Old May 8th, 2016, 02:58 PM
When the "inappropriate" LED turn signal flashes, is it slightly dimmer than the other signal flasher LEDs?
Old May 8th, 2016, 03:00 PM
LakeLBJ
CC
Correct, it is dimmer
Old May 8th, 2016, 03:14 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
If you want to test it...take out the bulb in the dash for the turn signal...they will work correctly...you need the resistors for the two front turn signal lights...
Old May 8th, 2016, 03:21 PM
I would offer that the simplest check is to make sure that all the grounds for all the turn signals have a clean connection. If you have any doubt, then clean the connections as much as possible. No rust, no white aluminum oxidation. No rusty screws, etc.
Have you tried this yet?
Old May 8th, 2016, 03:52 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
Mine worked just as described when I first put the LED's in...removed the turn signal indicator bulb...worked perfectly...put the resistors in, and put the bulb back in and works a 100%...
Old May 8th, 2016, 03:55 PM
This
Old May 8th, 2016, 04:21 PM
lordhelemt's Avatar
lordhelemt
Paul
1995 D90 #2620 & NAS 110
Check the polarity on the where the led was wired to the harness, on all LEDs.
RIP 1994 D90 #999 (engine fire 2002). We'll miss you.
Old May 9th, 2016, 11:28 AM
LakeLBJ
CC
Pulled the Wipac and it is clean, it's about a year old.
------ Follow up post added May 9th, 2016 11:29 AM ------
Can I get away with just two resistors (front only)? That should fix the back as well?
Old May 9th, 2016, 11:34 AM
Yes. The resistors can be anywhere.
Old May 9th, 2016, 02:09 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
If the side repeaters are still non led you have one burnt out. That will will cause the opposite side to flash as the power back feeds through the dash indicator.
Ryan
84 110SW County LHD
07 L322 Vogue
Old June 12th, 2016, 01:28 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Where and how are you guys mounting the WIPAC Smart Load Resistors - these things are big and bulky.
Weldon
Old June 12th, 2016, 01:30 PM
don't use them. Use the right flasher relay. They are a dirty hack not a proper solution.
Old June 12th, 2016, 01:31 PM
defender1844
Amit Likhyani
Ash switched me off wipac on to another LED brand and that appears to have fixed my issue. I do have the relay with the potentiometer. No extra resistors.
Old June 12th, 2016, 02:10 PM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
What is the right (best) flasher relay?
Weldon
Old June 12th, 2016, 02:16 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
I've used the adjustable flasher relay from RN. Fixes all trouble
signal
Turn Signal Failure arbik Defender Technical Discussions 53 October 11th, 2010 09:51 PM
Anyone have the turn signal Wagner/Bosch part number? arbik Defender Technical Discussions 5 February 2nd, 2008 09:33 AM
Rear turn signal light tron Defender Technical Discussions 3 December 5th, 2005 10:02 AM
Turn signal dfscott Defender Technical Discussions 5 November 28th, 2005 08:54 PM
Turn signal in the bumper! Bowtracer Defender Technical Discussions 20 June 7th, 2005 09:18 AM
