LED tail light wiring question - Defender Source
Old February 14th, 2015, 03:20 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I wired the LED brake lights up as follows;
Black to Black
Red to Red
Green to White.
The brake lights come on when I press the pedal if the tail lights are off, but if the tail lights are on, they do not get brighter when I press the brake pedal. This worries me. Is it correct of did I wire something up wrong?
Thanks in advance.
Paul.
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old February 14th, 2015, 03:37 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Mine were black to white. Can't recall the others. Will be home to check later
rankar's Avatar
rankar
97 SW #2236 (Maggie)
Which set do you have? Is it a straight up wiring job? Does it need inline resistors that you may be missing?
Old February 14th, 2015, 03:41 PM
On mine the colours did not match up. You need to test them to see which wires activate which light. There are basically two lights in the housing with a common ground.
Old February 14th, 2015, 03:42 PM
mlorman's Avatar
mlorman
Mark Lorman
95 ST #2782
Trucklite. I found a pic
Old February 14th, 2015, 03:51 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Update:
The lights are WIPAC. I thought they were plug & play but apparently not.
The plot thickens. If I have the lights off & turn then on with the ignition on, the led brake light 'turns on' & then stays on.
Completely flummoxed. Maybe swap the wiring so it's black to black, red to green & white to red?
------ Follow up post added February 14th, 2015 12:54 PM ------
Is the ground red or black?
Old February 14th, 2015, 03:57 PM
You need to TEST. Take the light off and figure out which terminal does which on its own. Power and ground to find out which is ground, which is brake and which is running.
Then TEST which is which on the truck and hook them up.
Don't guess.
What happens is the light ground through a light circuit when it is off. Most circuit. You most likely have the light ground hooked into the running light power. When the lights are off, the brake light can ground through the "other" running lights in the circuit.
Old February 14th, 2015, 04:09 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I can't test because I don't have anyone to hold the brake pedal whilst I test!
I swapped it so we have Red to Red, Black to White and Green to Black. Now the tail lights work but when I press the brake pedal, the light goes out instead of getting brighter.
Paul.
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Wipec earth is green, source is coloured wire , brake red with orange tracer, indicator green with something
Land Rover earth is black
US trailer earth is white
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 14th, 2015, 04:11 PM
You put a toolbox or whatever heavy against the pedal to turn it on.
Old February 14th, 2015, 05:25 PM
87 D110 (Ruby)
use a long screwdriver or pry bar on the brake pedal and wedge it against the seat, slide the seat forward. Just get creative and use a circuit tester
Old February 14th, 2015, 05:34 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Except that's not what I have. My WIPAC unit has Black, white & red wires.
And I don't know which is which.
Old February 14th, 2015, 05:53 PM
roverman2010
1985 LR 90 200Tdi
Ok, you made me get off my fat arse to check out mine so here goes
white to red black
red to green purple
black earth
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 14th, 2015, 06:15 PM
drdread's Avatar
drdread
AL
'94 NAS 90 SW
Also make sure your bulb has two filament style to make sure it'll do the 2 functions.
It's not automatic
1994 Silver DEFENDER 90 NAS SW
Old February 14th, 2015, 07:19 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
All:
I figured it out...sorta.
Land Rover WIPAC
Green Red
Red White
Black Black
...Works great, except now my brake lights flash with my turn signals.
I can live with that.
Thanks for the help.
Paul.
Old February 14th, 2015, 07:41 PM
That means you have a ground problem in the back. Check where the grounds go.
Old February 14th, 2015, 08:39 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Old February 15th, 2015, 09:53 AM
roverman2010
1985 LR 90 200Tdi
Did you wire in the SDL 124 from Roversnorth? If not replace your front ing lights for the old bulb type and your brake lights will stop flashing.
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 15th, 2015, 11:16 AM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
Thanks- will try that today.
Old February 15th, 2015, 02:09 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
If not replace your front wing lights for the old bulb type and your brake lights will stop flashing.
Sadly didn't work. Time to buy an SDL 124...
ht, wiring
Tail Light Boot Installation - Fixing Hosed Tail Lights JimC Misc. Chit-Chat 1 July 11th, 2017 04:14 PM
LED Tail Light Installation WD90 Smaller Projects 15 March 18th, 2014 09:25 AM
Question about LED Tail lights BlackField Defender Technical Discussions 4 December 5th, 2013 09:47 PM
LED tail lights question BadMonkey Defender Technical Discussions 3 November 10th, 2011 03:59 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
