LED running light bulbs - Defender Source
Old March 17th, 2008, 08:29 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
'94 D90, '07 D110, '08 LR2, '09 D90
I'm replacing all of my outside bulbs with LED's. So far, so good...except.....The front 4 running lights just won't work with the LED's. The blinkers, brake/tail lights, side markers, liscence light are all OK. Just the front four amber running lights. What gives? Is there a way to make them work? Regular bulbs work fine in the sockets. Thanks!
Old March 18th, 2008, 10:26 AM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Hello Joe,
I think it has soemthing to do with with lower current draw of the LEDs and the flasher relay. I believe you may find some help in a previous post from Mike at ECR.
Joe
'93 110
'95 D90
Old March 18th, 2008, 07:47 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Hey Joe...
Thanks for the reply. I did replace my flasher relay with an electronic one, and the LED turn signals work just fine. I'm going to try and replace all four running lights simultaneously and see if that makes a difference. Maybe the larger current draw from the other three regular bulbs may be slighting the one I'm replacing with a LED. I'm grabbing at straws here though.
Addendum...the 4 bulb simultaneous thing!.....didn't work.
Old March 18th, 2008, 08:54 PM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Hi JB,
LED's are aslo polarity specific so you wish to check the holders before inserting LED light bulb.
Joe
Old March 18th, 2008, 10:19 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Joe,
I think you are on to something! Would that mean simply turning the bulb 180 degrees and inserting it, or would I actually have to reverse the wires? I already tried the 180 deal. Let me know your thoughts before I go cutting and splicing wires.
Regards,
Joe
Old March 18th, 2008, 11:45 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Chances are your bulb uses the outer part of the holder as negative, and the tip of the bulb as positive. If so, that means you'd have to switch the wires, because no matter which way you turn the bulb, it isn't going to reverse positive and negative.
Old March 19th, 2008, 01:25 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Do you have the right bulbs? You need bulbs with two terminals if they operate as both turn signals and parking lights. If the bulbs you have only have a single positive terminal it is probably not making the correct connection.
Old March 19th, 2008, 06:14 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
I do have the right bulbs, single terminal. These are just the four amber parking lights surrounding the headlights on a '94. Thought if I were to have a problem, it would have been with the turn signals or dual purpose bulbs (tail/brake), but noooo. I remember reading about the polarity thing somewhere too. I will report back once I swith the wires.
Old March 19th, 2008, 11:07 AM
Joeplumbo's Avatar
Joeplumbo
Joe PLumbo
1993 110
Hi Jb,
You may wish to test with a meter instead of the LED bulbs...may blow out a bulb.
Joe
Old March 19th, 2008, 11:20 AM
cellulararrest
Chris Snyder
Out of curiosity, what bulbs are you using and where did you get them from? I would like to do the same thing eventually.
Old March 19th, 2008, 10:07 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Hi Chris...
If I get them to work, I will post results. I'll also post the bulb #'s from Super Bright LED's and the positions that I used the bulbs in. I'll try to get to it on Friday.
http://www.superbrightleds.com/index.htm
Regards.
Old March 26th, 2008, 06:54 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
Originally Posted by JBfoot
Hi Chris...
Regards.
Quick update...
Reversing the wires to the connector on the four amber running/parking lights worked! Thanks! For '94 owners (or '93 110's), the two signal indicators in the bumper are made by Trucklite. They are sealed units, model 60, 6 inch ovals. I tried to buy a new base, just like the original, but with replaceable bulbs so that I coud use LED's there. I couldn't find that trucklite made a light that accepted the single contact type bulb. By mistake, I ordered a light that had a replaceable bulb feature, but only accepted a double contact (such as used in brake/tail light combos). Trying to rewire this just caused funny things to happen with the other lights. So I decided to try a unit that is sealed with built in multiple LED's. Won't look completely stock (maybe better), but I ain't going to win a concours show anyway. When they arrive, and if they work, I'll repost the bulb numbers in the various positons, and a pic of the signal indicators if I can figure out how to post a pic.
Old March 26th, 2008, 09:20 AM
themaxx's Avatar
themaxx
Ade
94 ST
Thanks for the update! Could you also include what bulbs you used for the side markers and license plate light?
Old March 26th, 2008, 10:49 AM
JBfoot's Avatar
JBfoot
Joe Barefoot
Bulb #'s
OK..here goes...front to rear. Realize that there are options for these positions, and different bulbs could be chosen. I did make several mistakes, but Superbright LED's was gracious and will refund my poorly chosen purchases. Again, I'm waiting on the turn indicators in the front bumpers and will report back on them.
Site is: http://www.superbrightleds.com/index.htm
Position, Bulb number, Number needed
Front Parking, 67-A9, #4
Front side marker, Amber WLED-R6, #2
Rear side marker, Red WLED-R6, #2
Tail/brake, 1157-R24 wide, #2
Rear Signal, 1156-A24 wide, #2
Back up (reverse), 1156-W24 wide, #1
Liscence Plate, White BA9S-W4-12V, #2
Peace out....and, Tinkerbell is a fairy!
Old March 26th, 2008, 11:35 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Nice! Can we get pictures?
Old March 26th, 2008, 11:43 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
You didn't find a replacement for the three in the 'third brakelight' above the tire by chance, did you? Would be nice if they matched...
~Scott T.
'95 D-90 ST - AA Yellow
Old March 26th, 2008, 01:12 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Oh yea...forgot the "high" brake lights...
They are same as the side marker rears...
Red WLED-R6, #3
As for pics, they look stock as they are behind the original lenses. There is a subtle difference when they are lighted...I think it adds a slightly more modern look, which I happen to like...again subtle. I will post a pic of the front turn signals when I get them. They will look quite different I'm guessing.
Old March 26th, 2008, 01:27 PM
Abrooks's Avatar
Abrooks
Tony Brooks
So they're not necessarily any brighter than the regular bulbs?
Old March 26th, 2008, 01:51 PM
JBfoot's Avatar
JBfoot
Joe Barefoot
Not to my eyes. They do have a few "bright" LED's that are suposed to be brighter than filament bulbs. The disadvantage is that they are more directional and tend not to "fill up" the lens with light, like the LED's that I listed do. The colored LED's do make the lenses appear a few shades lighter when lighted. The are also instant on/off so the turn signals blink sharper and the brake lights come on and go out faster. The main advantage is that they don't burn out. Theoretically, it will be the last bulbs that you change. I personally like the subtle lens color change and lighting pattern change...your mileage may vary.
There is some good general info on LED's at the site that I posted.
Old April 11th, 2008, 07:44 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
post pix pls
I'm contemplating thinking about thinking about it!
ht
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
how many forum members does it take to change a light bulb? brn24whl Misc. Chit-Chat 14 December 4th, 2009 09:07 AM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
Dash, Running & Head light PROBLEM ! Weldon Defender Technical Discussions 5 November 9th, 2005 02:04 PM
DS Running light? Eric Siepmann Defender Technical Discussions 1 June 27th, 2004 07:55 PM
