led replacement bulbs for dash gauges - Defender Source
Old October 30th, 2004, 08:01 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
Smile led replacement bulbs for dash gauges
the bulbs needed are 4, #194 equivalent wedge type led replacements. available at most large auto parts stores. You aslo need 1 #1816 equivalent bayonet type led replacement. available at www.ledtronics.com part #BF3126-OCW-014B. probably can get 194's at ledtronics also. All these bulbs are 2-3watt 12-14v specs. i also replaced lower left dimmer switch (old one shot) and now i can see the dash at night. good luck, marc w.
Old November 1st, 2004, 03:50 PM
paulb's Avatar
paulb
Paul / Boultbee
1994 D-90, Green #1576
Marc,
did these really juice up the dash read out that much?
What wast he total $$ ?
Old November 1st, 2004, 08:59 PM
Marc Weinstein
Marc Weinstein
defender 90 '94
paul, yes, you can actually see the lights during the day,although not like modern dash gauges but, the night visability is way better! Marc W.
paul, yes, you can actually see the lights during the day,although not like modern dash gauges but, the night visability is way better! Marc W. The led bulbs average about 7-10 dollars each.
Old November 2nd, 2004, 04:40 PM
smenzel's Avatar
smenzel
Sandro
1967 Series IIA
Marc, do happen to recall which of these bulbs work with which gauges?
Old December 23rd, 2004, 03:30 PM
jaherring's Avatar
jaherring
Jason Herring
94 D90 ST #1253
I found this company, whose LED replacement bulbs are *much*cheaper than ledtronics:
http://stores.ebay.com/superlumination
At those prices I can afford to try them out and toss them if I don't like the effect...
EDIT: OK, I just ordered some for my dash. I'll post here how they work out. If good, I might grab some for the side marker/tail/etc.
Old December 24th, 2004, 04:34 PM
Just had a look at my ex-MOD 90. It has 4 type 194 bulbs (2 for speedo and 1 for each gauge).
That eBay store has its own website, which is easier to view and buy from: http://autolumination.com/194.htm
Do NOT get the wide bulds as they are fit into a tunnel (5 LED matrix or 6 LED). I'm not sure what is best, either the 4 LED or the Oval.
Bulbs sepcs here
Old January 5th, 2005, 10:00 PM
I purchased the 4 led focused units in green. They make the gauges about 50% brighter. They do not fully insert into the green filters as they are a little wider than the 194 incandecents but it doesn't seem to matter.
Old November 24th, 2011, 02:10 AM
ttoppins
Anthony Toppins
94 Defender 90
94 NAS Defender 90 LED Dash replacement bulbs
Hi everyone. Thanks to your help I bought and installed replacement bulbs for my dash instruments in my 94 NAS D90. I used the 6 LED Green wedge base bulbs for speedo, fuel and temp. my tachometer used a 9mm bayonet base 4 LED green. They are sooooo much brighter!!! The speedo in particular is extremely bright now but not too much. I also replaced the dome light bulb with a tower bulb. It was expensive but makes a huge difference in cabin lighting at night. Here are the part numbers from superbrightleds.com:
WLED-x6: 6 LED T10 Wedge Base Bulb | $ 3.94 | speedo, fuel, temp
WLED-G6: Green
1156-x18-T: 18HP-LED BA15S Tower Bulb | $ 17.95 | dome light
1156-CW18-T: Cool White
BA9S-x4-x-xV: 4-LED BA9s Bulb | $ 2.98 | tachometer
BA9S-G4-90-12V: Green 90 Degree 12V
www.superbrightleds.com they shipped super fast from st louis.mo. highly recommend them.
Old November 24th, 2011, 06:35 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Here's my complete list of all the lights I replaced with LED. Dash gauges were upgraded to VDO Vision Black and I used WLED-GHP5 bulbs for all gauges except tach which is 74-GHP3.
http://www.defendersource.com/forum/...1&postcount=82
Old November 26th, 2011, 11:13 AM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
video
Great video on youtube.
Old November 26th, 2011, 11:35 AM
bjf's Avatar
bjf
barry f
94 ST #395
Originally Posted by Rosproline157
I think there are five pages of us discussing the Aussie. If the lights
Are good enough for the bushman they are good enough for me. In fact I ordered from Australia after watching this.
Old November 30th, 2014, 07:19 PM
wmatos1001's Avatar
wmatos1001
William
1994 NAS Defender 90
WLED-G6: Green
Just wanted to say to all thanks for this post. Just today I replaced my 1994 Defender 90 Dash lights with LEDs from www.superbrightleds.com and wow what a difference! This thread helped make it about a 10 minute job no kidding.
Only issue is when I put everything back together and drove it for a bit I noticed I must have pulled the speedometer cable loose a bit because now the speedo doesn't work. But it lights up bright as can be! I will fix that tomorrow hopefully without issue.
For the speedometer (2), temp (1) and fuel (1) I used the: WLED-x6: 6 LED T10 Wedge Base Bulb | $ 3.94 | WLED-G6: Green.
For the tachometer I used (1) BA9S-x4-x-xV: 4-LED BA9s Bulb | $ 2.98 |BA9S-G4-90-12V: Green 90 Degree 12V
The spedo has two bulbs so it is quite bright and the other gauges are at least twice as bright as stock and look really good in the Green LED glow.
Simple as unscrewing the dash screws, pulling the dash out a bit and using your hands to just pull the lights out of their white sockets and insert the new LEDs.
For the tachometer the socket is aluminum or tin and pretty long so it is hard to get your hands back there. I found using a needle nose pliers helped to pull the existing bulb out of the socket.
To anyone thinking of an LED dash upgrade I would say don't waste time thinking about it. The LEDs are quite inexpensive, the install is very easy (maybe 10-15 mins) and the results are fantastic!
Old December 3rd, 2014, 07:00 PM
RoverC
Cliff
1997 D90 ST
Has anyone tried to replace the dimmer switch with one like most cars have that are adjustable?
It would be nice to have another option other than bright and dim
Old December 3rd, 2014, 09:29 PM
A question for those who have completed this swap. I can now read the speedo at night so that goal has been met.
I purchased these EBay Bulbs and installed them. I have a mix of new VDO Vision and old LR stock gauges. My dash now looks like this:
I still have the green bulb filters in the gauges. Does anybody else have a mixed bag of gauges and pulled out the green filters? I'm wondering what they look like illuminated.
Old December 3rd, 2014, 09:38 PM
87 D110 (Ruby)
Dave my vdo' all look like yours...as does my speedo. I pulled (read broke) the light housing and green filter in both speedo globes and it still doesn't match with the same bulbs
Old December 3rd, 2014, 09:47 PM
So you're saying you DO have the green "sock" on the VDO bulbs behind the gauges? They look white for some reason (could just be the pic).
One thing I'd suggest is to swap in the VDO fuel gauge and ditch the stock fuel gauge...at least that way all the small gauges would match. It's a straight swap for the fuel gauge, no need to change the sender.
Old December 3rd, 2014, 09:56 PM
No socks on the VDO gauge bulbs. I'm debating drilling out the green socks on the speedo and am looking if anybody else has tried this.
Jason is your VDO fuel gauge all bouncy or is the dampener in the sender?
Old December 3rd, 2014, 10:11 PM
Your VDO Vision should have come with the bulb socks (one green, one red)...I'd say slap on the green ones and it may blend better (in my opinion...that's what I did).
No my fuel gauge doesn't bounce around at all, I swapped the VDO Fuel into both the NAS90 and ROW130. It's VDO 301-105.
Old December 3rd, 2014, 10:15 PM
Ill give it a try, thanks.
Old December 3rd, 2014, 11:53 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Hey now...
ac, dash
LED bulbs. ajh Defender Technical Discussions 0 July 21st, 2009 12:19 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
replacement bulbs milli Defender Technical Discussions 3 January 25th, 2005 10:00 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
