led replacement bulbs for dash gauges - Page 4 - Defender Source
Old November 29th, 2015, 07:47 PM
marrat's Avatar
marrat
Jamison
1995 Defender 90
I got the part numbers from earlier in the thread:
Www.Superbrightleds.com
The first 3 are for Temp, fuel, and speedo. Second is for the Tach, and the last is for the dome light
3 WLED-G6 green
1 BA9S-G4-90-12VAC
1 1156-CW18-T: Cool White
Old December 18th, 2015, 07:57 AM
jarg
alonso
1997 defender 110
Originally Posted by bjf View Post
I think there are five pages of us discussing the Aussie. If the lights
Are good enough for the bushman they are good enough for me. In fact I ordered from Australia after watching this.
Quote:Originally Posted by Rosproline157
Great video on youtube.
Doing a search and comparing the results i think the light on the video looks very nice, i found the Leds that he used, and this are 180 angle.
2pcs Car Side Indicator Dash LED Light Bulbs Pure White 194 168 W5W 1250 2825 | eBay
Old December 27th, 2015, 10:11 PM
DrZ123
Zach
Did these work?
Old December 27th, 2015, 10:57 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
Question
Originally Posted by marrat View Post
Super happy with this upgrade! And I only broke one mounting tab in the process😄
Attachment 135859
Did you re-arrange your gauges? From left to right, mine are tach, temp, fuel then speedo.
Old December 27th, 2015, 11:02 PM
DrZ123
Zach
I don't even have a Tach. Just fuel, temp, fluid, and Speedometer. Is it hard to replace on with a Tachometer??
Old December 27th, 2015, 11:11 PM
Birdman's Avatar
Birdman
Chris Bird
1995 D90 ST #2046
simple, same as the other gauges
Old December 28th, 2015, 08:07 AM
DrZ123
Zach
The little black sleeves on the back of my guages that the light bulbs slides into, one of them is broken off.
What is the best solution for that?
Old January 23rd, 2016, 09:02 PM
LRColorado
1990 Defender (200 TDI)
Will a 28 mm replacement led bulb be too long? If so what use longest that would work?
Old February 6th, 2017, 10:46 PM
BayouBeastie
Corky Jones
97 D90 LE ST Conversion
Just replaced the tach, fuel and temp gauges with the green Super Bright LEDs. Amazing how much better they make the dash look.
Question: When I pulled the two out of the speedometer they look like there might be a wedge in the removable blue base. Or is the base part of the bulb? Didn't want to pull out what I thought was the wedge and find out I was pulling apart a bulb.
ID:	203962   Click image for larger version
Old February 6th, 2017, 10:58 PM
Without reading the thread, you have a 97, which uses VDO gauges. Completely different than all prior Rover type gauges.
Old February 7th, 2017, 12:03 PM
BayouBeastie
Corky Jones
I found what I think are the replacements. The speedometer bulbs appear to be 509T models.
I found the LED green colored ones from car-mod-shop.co.uk. Should arrive later this week. I'll repost when I have confirmation of fit.
Hope this helps the other NAS 90 owners.
Old February 19th, 2017, 04:16 PM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Edit: google found this post of LED replace for NAS 1997 trucks. For future reference
http://www.defendersource.com/forum/...edo-34846.html
<ignore>
Any update on fitting LED gauge bulbs in your '97 NAS?
What bulb sizes are needed in your '97? I think most of the posts here are of 94-95's.
Thanks!
</ignore>
Old February 20th, 2017, 12:00 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
<ignore>
Thanks!
</ignore>
Thanks for bumping this, Chris.
I am also trying to light a '97 cluster. I already had the gas,temp gauge as they are the same as older trucks.
It seems the 97 speedo uses the B8.5 size which is different than they were a few years back.
I wonder if these in green will work?
https://www.superbrightleds.com/more...l-led-car/223/
Also, the tach is another type of bulb and the hvac lights look like the same size but they are green.
Rent my
Old February 20th, 2017, 12:15 PM
lithium1330
'97 SW NAS 4.6
per the PDF in other post I referenced, i order 2 of the 8.5D's in green for speedo yesterday, along with 74-G size bulbs for tach, heater & fan switches. I will confirm once I get them and installed.
Old May 14th, 2017, 12:00 AM
lithium1330
'97 SW NAS 4.6
I just swapped to LED's for the gauge cluster - this is for a '97 NAS.
The LED's I ordered _for the gauge cluster_, per the PDF mentioned in post 72 above, was spot on.
I used a 9v battery to confirm +/- before installing them into the cluster. The only LED's I wasn't able to test with the 9v were the ones for the speedo - I couldn't figure in the cluster socket which is + or -. So, that was trial & error.
Hope this helps others.
I used the tach bulb socket (74-G LED) & 9v batt to confirm +/- before installing them
Name:	LED 9v tester.jpg
bulb for the heater controls (sides of cluster) & tach
Name:	LED heat and tach.jpg
bulb of the heater controls
Here is back of the cluster (L to R: fuel, temp & tach). Fuel & temp use T13-G6. Tach uses the smaller bulbs 74-G, same as heater controls.
Name:	LED LtoR fuel temp tach.jpg
Speedo & bulbs. I had to slightly bend up/down the contacts to make sure they make contact with the PCB.
Name:	LED Speedo.jpg
LED on bright setting - good setting, not blinding, looks more washed out with cam trying to compensate the contrast.
Name:	LED bright.jpg
LED on dim setting (oddly only the T13-G6's and one of the speedo dim). So, basically not usable at night.
Hope this helps others with '97 NAS.
Old October 21st, 2017, 03:52 AM
emah's Avatar
emah
Ed Mah
1993 NAS D110
Tach bulb...how do you remove it?
How does one remove the bulb on the tach? On my 110, its a long aluminum tube but it sealed on the end. its a white incorporated cap with the electrical tab on the end bent in 90 degrees.
Someone above mentioned using a needle nose plier
but on my socket, There is nothing I can see where you can remove it. Anyone have this problem?Thanks,
Eddie
ac, dash
LED bulbs. ajh Defender Technical Discussions 0 July 21st, 2009 12:19 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
replacement bulbs milli Defender Technical Discussions 3 January 25th, 2005 10:00 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
