led replacement bulbs for dash gauges - Page 3 - Defender Source
Old December 14th, 2014, 10:14 AM
ymc226
Lawrence
1995 D90 SW NAS
Originally Posted by kevincdoyle View Post
Here is a picture to give you an idea. It doesn't unscrew, you just sort of squeeze it and it should come right off.
Attachment 108665
Thanks Kevin. I'll give it a try.
Lawrence
Old December 14th, 2014, 11:13 AM
UTRPh's Avatar
UTRPh
Danny V
94 D90 #1260
Squeezing that cable
When I replaced my bulbs I tried hand squeezing it too. Ended up using a small set of channel locks and very gently squeezing it & pulling it off. Gently is key word, that white plastic may get brittle.
Anything worth doing is worth getting carried away with(ancient druid saying)
Old December 17th, 2014, 08:40 PM
Has anyone converted to red/orange? White and green always seem a bit harsh at night, especially when its raining.
-Jeff
Red LED's. Both the speedo bulbs are working. I'm not sure why it is half lit and half dark.
Old December 18th, 2014, 01:16 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
At least it's not the half that you would normally see. The red looks good though.
Old December 18th, 2014, 09:29 PM
I modified the speedo and it lights up much better.
Old December 18th, 2014, 10:07 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Did you remove the green filter or just plug the red right in?
Old December 18th, 2014, 10:13 PM
Here is what I did.
1) Carefully drilled out the green lens that lights up the 11:00 position of the speedo. You need the sides of the green lens to hold the bulb holder to the back of the speedo so be careful.
2) Remove the rubber cap and relocate the other bulb holder to that position. In my case I had a spare bulb holder so I just 5 min. epoxied it into place.
3) Add a few red LED bulbs and you are done.
Old December 18th, 2014, 10:58 PM
Let the record show, the 4-led bulbs are much better suited to the gauge application than the 6....I decided to swap and am much happier with the results:
ID:	108943   Click image for larger version
Old December 18th, 2014, 11:06 PM
Way better but they still look mega bright. Is it a picture thing or are they still super bright?
Old December 19th, 2014, 02:16 AM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
javelinadave, did you drill out the green on the other gauges as well?
Old December 19th, 2014, 10:41 AM
I swapped them all out for VDO gauges.
Old December 19th, 2014, 11:21 AM
They are really not as bright as they look in the pics...for example, look at the "headlight icon" on the binnacle - which looks almost washed out (and obviously it's not in reality). The 4-led is the perfect middle ground for brightness on these gauges, I put them on the speedo & the VDOs and it's much better than the stock bulbs (too dim) and the 6-led (too bright).
Old May 23rd, 2015, 11:51 PM
jperakis
James Perakis
94 ST
Just installed the exact same lights as you mention in my 94st.
The tach looks awesome but everything else is still dim. Like the light isn't getting through.
I've confiemwd all lights work as I can see them glowing with the dash removed.
Thoughts on where I'm going wrong?
And in case it matters I have all the stock gauges in my truck
Originally Posted by wmatos1001 View Post
Just wanted to say to all thanks for this post. Just today I replaced my 1994 Defender 90 Dash lights with LEDs from www.superbrightleds.com and wow what a difference! This thread helped make it about a 10 minute job no kidding.
Only issue is when I put everything back together and drove it for a bit I noticed I must have pulled the speedometer cable loose a bit because now the speedo doesn't work. But it lights up bright as can be! I will fix that tomorrow hopefully without issue.
For the speedometer (2), temp (1) and fuel (1) I used the: WLED-x6: 6 LED T10 Wedge Base Bulb | $ 3.94 | WLED-G6: Green.
For the tachometer I used (1) BA9S-x4-x-xV: 4-LED BA9s Bulb | $ 2.98 |BA9S-G4-90-12V: Green 90 Degree 12V
The spedo has two bulbs so it is quite bright and the other gauges are at least twice as bright as stock and look really good in the Green LED glow.
Simple as unscrewing the dash screws, pulling the dash out a bit and using your hands to just pull the lights out of their white sockets and insert the new LEDs.
For the tachometer the socket is aluminum or tin and pretty long so it is hard to get your hands back there. I found using a needle nose pliers helped to pull the existing bulb out of the socket.
To anyone thinking of an LED dash upgrade I would say don't waste time thinking about it. The LEDs are quite inexpensive, the install is very easy (maybe 10-15 mins) and the results are fantastic!
remember two things...
Old May 24th, 2015, 12:14 AM
EnduroPro's Avatar
EnduroPro
Stephen LeBlanc
1994 Defender 90
I'll be following the results of this. My dash is apart so I might as well throw some better bulbs in. The originals are horrible.
Old May 24th, 2015, 04:39 PM
jperakis
James Perakis
94 ST
Ok so I drilled out the green bulb lenses but I was caution about how much to drill.
What size drill is best for this job?
Also, I just saw first hand how easy it is to disconnect the speedo and damn no wonder mileage fraud is such a real concern with these vehicles. Does the vdo speedo have any additional security or is it simply controlled by one ( easily detached ) cable as well ?
------ Follow up post added May 24th, 2015 01:42 PM ------
Also I installed an interior overhead led at the recommendation of this thread and wow what a difference.
I'm currently underwhelmed by the gauge leds ( hopefully a little more drilling will help), but the overhead led is just awesome
Old May 24th, 2015, 04:44 PM
ruggedalaskaman's Avatar
ruggedalaskaman
Frank
1995 NAS D-90 #375
Subscribed
Old May 24th, 2015, 04:49 PM
I don't recall the drill bit size but I milled out the green plastic as best as I could and it made a HUGE difference!
Old May 24th, 2015, 05:28 PM
Hmmm...which SPECIFIC leds did you get? They were plug & play for me on both the '94 & '88
Old November 29th, 2015, 04:40 PM
marrat's Avatar
marrat
Jamison
1995 Defender 90
Super happy with this upgrade! And I only broke one mounting tab in the process😄
Old November 29th, 2015, 07:19 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
What part number is the 4-led bulbs?
ac, dash
LED bulbs. ajh Defender Technical Discussions 0 July 21st, 2009 12:19 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
replacement bulbs milli Defender Technical Discussions 3 January 25th, 2005 10:00 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
» Defender Registry
Hot Water
Wilboro
D90
NPT90
Add your Defender
