led replacement bulbs for dash gauges - Page 2 - Defender Source
Old December 4th, 2014, 10:10 AM
87 D110 (Ruby)
Dave I have done all 3 like Jason in my ROW110 and have put LED greens in. I had white and they were too bright. For some reason the ones I have put in glow green on the edges, but the VDO dial is white. The speedo sux. Like I said I broke and took out both plastic pieces including the green lens in there.
I will post up pics for you tonight.
Old December 4th, 2014, 11:02 AM
FWIW I actually ordered up these for my speedo(s) earlier this week actually (in the GREEN color):
https://www.superbrightleds.com/more...-base/200/885/
They are set to deliver today or tomorrow, and I plan to do the swap this weekend. We'll see if it gives me more of a "green" glow like the VDO's that I have in the other spots....I'll report back.
Old December 4th, 2014, 11:17 AM
kevincdoyle's Avatar
kevincdoyle
Kevin C. Doyle
FWIW I actually ordered up these for my speedo(s) earlier this week actually (in the GREEN color): https://www.superbrightleds.com/more...-base/200/885/ They are set to deliver today or tomorrow, and I plan to do the swap this weekend. We'll see if it gives me more of a "green" glow like the VDO's that I have in the other spots....I'll report back.
That's it?!! For some reason I thought you had to have some sort of nuclear diffuser whenever you switched to LED. These I could learn to like although I don't think I've ever driven the 90 at night!
Attributed to Shayne...
Old December 4th, 2014, 11:21 AM
Originally Posted by RoverC View Post
Has anyone tried to replace the dimmer switch with one like most cars have that are adjustable?
It would be nice to have another option other than bright and dim
I have a dimmer. It is needed when you get VDO gauges.
Old December 4th, 2014, 11:59 AM
The only time it gets complex (I believe) is when you have a relay involved....but others have done the LED gauge lights swap with great success. I actually do NOT plan to swap out the bulbs on my VDO since they are nice and bright, but only plan to do the speedo, (tach has a different bulb requirement FYI), and interior light.
Old December 4th, 2014, 12:31 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Hey now...
Old December 11th, 2014, 09:01 AM
87 D110 (Ruby)
here you go - 3VDO's and standard speedo.
Old December 11th, 2014, 09:03 AM
Is that with the LED upgrade on the speedo?
Old December 11th, 2014, 10:48 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
A follow up question. If so, what color led bulb did you put in - warm white, natural white or green?
Old December 11th, 2014, 11:30 AM
87 D110 (Ruby)
yep - in both sockets...unfortunately the speedo sockets all rotted away - crappy English plastic so the LEDs don't fit in there snuggly, hence a lot of light leakage - but still way bright enough
------ Follow up post added December 11th, 2014 11:30 AM ------
Originally Posted by rover26c View Post
a follow up question. If so, what color led bulb did you put in - warm white, natural white or green?
green
------ Follow up post added December 11th, 2014 11:38 AM ------
here are the ones I put in there....90deg of course
https://www.superbrightleds.com/more.../attributes/15
Old December 11th, 2014, 11:48 AM
Bill Larson
Bill Larson
Has anyone converted to red/orange? White and green always seem a bit harsh at night, especially when its raining.
-Jeff
Taking mine to red...roadside.
Old December 11th, 2014, 12:06 PM
-Jeff
I just ordered red LED's. I'll post photos once they are installed.
Old December 11th, 2014, 12:09 PM
Bill Larson
Bill Larson
streaming video please...
Old December 11th, 2014, 05:36 PM
I installed the green LEDs in the speedo today:
...WHOA. I don't want to say it's too bright, but man. I left the regular bulbs in the VDO fuel/temp gauge, and realized now that the clock bulb is different, so I'm tempted to order up the LEDs for the VDO as well and figure out which bulb for the clock (though I'm thinking of ditching the clock for a battery voltage gauge anyhow so maybe I'll hold off).
Anyhow...at least now I'll finally know how fast I'm going at night!
ID:	108498   Click image for larger version
Old December 11th, 2014, 06:44 PM
What about a mini tach instead of a voltage gauge?
-Jeff
That's actually not a bad idea.
Old December 11th, 2014, 06:54 PM
how will you overcome the oe green lensed bulb holders ? The vision series VDO's are easy since they come with different color bulb condoms.
Old December 11th, 2014, 07:07 PM
I'm going to spin a drill bit with my fingers or slowly with a variable speed drill and grind out the green lens while holding the speedo face up so the waste falls out.
Old December 12th, 2014, 03:16 PM
Did the NAS today, pics are during the daytime so not as "dramatic" but you can see the obvious improvement. I did just the speedo, tach, and interior light (not pictured)...but am strongly considering doing the VDO gauges on both trucks with the LED as well so everything "matches".
ID:	108537   Click image for larger version
Old December 14th, 2014, 09:59 AM
ymc226
Lawrence
1995 D90 SW NAS
I took off the dash but can't for the life of me pull off the speedo cable. I've loosened the large white "base" of the connector (that just sits right next to the speedo) with counter clockwise rotation but when I keep on turning it, it doesn't come off. It also won't pull off at this stage. What am I not doing right?
Old December 14th, 2014, 10:07 AM
kevincdoyle
Kevin C. Doyle
Here is a picture to give you an idea. It doesn't unscrew, you just sort of squeeze it and it should come right off.
ac, dash
LED bulbs. ajh Defender Technical Discussions 0 July 21st, 2009 12:19 PM
New LED rear tail & stop light bulbs FlaD90 Smaller Projects 2 July 21st, 2008 02:10 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
replacement bulbs milli Defender Technical Discussions 3 January 25th, 2005 10:00 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
