LED Options - Page 2 - Defender Source
Old July 28th, 2011, 11:55 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Kevin,
Will you post pictures once you have them on? I take it that the you could just take the new mounts to get powdercoated?
Old July 29th, 2011, 09:08 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
Sure
PC, Paint, anodize are all possible
Old July 29th, 2011, 09:50 AM
ersatzknarf's Avatar
ersatzknarf
Frank
'96 hybrid
Agreed ! ! !
Originally Posted by 97-D90-736 View Post
I really dig these. The plastic just looks fragile next to the metal.
Old July 30th, 2011, 04:30 PM
Chris Velardi's Avatar
Chris Velardi
Chris Velardi
1975 101FC
I have been looking for a similar set up for my 101FC. I created a 8"x2" 3/16" wall rear cross member for the 101 and what to keep the wiring inside the tube instead of the direct path of everything the rear tires kick up same problem the perfect US led are too large especially when you add the trim rings. You look like you might have the perfect answer keep me informed with your progress Chris at one0one@gmail.com
Chris "V"
Old August 1st, 2011, 04:44 PM
Chris Velardi
Chris Velardi
1975 101FC
Here is a photo of the stock rear turn signal shown held in place on the tubular 8"x 2" custom bumper I would like to keep the wiring inside the tube not right though both sides of the bumper and into the wheel well.
Chris "V"
Old August 2nd, 2011, 08:56 AM
kevkon's Avatar
kevkon
kevin
Chris, I don't see why it couldn't be done with aluminum conduit.
Old August 2nd, 2011, 12:21 PM
Chris Velardi
Chris Velardi
1975 101FC
I could use a conduit but I would rather uses a surface mounted plinth with a 4" Grote LED exactly like you are making for the 90 and keep the wires right in the tubing let me know if and when you make them (anodized black gets my vote )
Chris "V"
Old August 2nd, 2011, 12:34 PM
kevkon's Avatar
kevkon
kevin
Chris, I was thinking about the surface mount w/ aluminum conduit since it could be threaded and sealed, although there is no reason you couldn't use some other tubing as well. Nice thing about the Grote and Trucklite Leds is that they are sealed pretty well and the Grote has a special pigtail plug with grease. The only down side is that both have the plug at the bottom rather than the middle on the back.
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
Packing the Hub bearings sflash868 Defender Technical Discussions 11 May 22nd, 2008 03:32 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
exhaust- options Nigel Defender Technical Discussions 11 October 20th, 2004 10:34 PM
