LED lighting issue - Defender Source
Old February 5th, 2016, 11:42 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
LED lighting issue
I've installed a set of LED lights on all 4 corners of a 95 D90, as well as a electronic flasher. The issues are:
1)
If either turn signal is active when the brakes are applied, the opposite turn signal illuminates dimly, but only on the front!
2)
The Trailer icon does not illuminate with or without a trailer connected.
3)
If I disconnect the factory trailer wiring connector that has a Hoppy convertor in-line, issue #1 goes away. Issue #2 doesn't change
I have substituted another convertor from Hopkins, reviewed ground connections, removed the indicator bulb- had installed a blocking diode harness to prevent backfeed for the common indicator lamp.
I'm pretty sure the customer would be okay with connecting the convertor harness to the factory plug on the occasion he uses the trailer, but I'd really like to figure this out!
Any ideas?
Email is
Same place, new dogs.
Old February 5th, 2016, 11:47 AM
You need to put in resistors in-line. At least in the front. I didn't need them when installing rear-only.
Old February 5th, 2016, 11:48 AM
1 sounds like you are get back feed through the trailer converter. Bad converter design?
The trailer light relies on amount of power being used and you would probably need to add in a resistor to suck down power if you really wanted it....
Old February 5th, 2016, 02:15 PM
Roverlab
Trevor Griffiths
Hmmm, resistors, yes, well, that sorted that out. Still, I wonder why the issue was only on the front lights?
Email is
Old February 5th, 2016, 02:53 PM
Who knows. It's all shared somewhere. My front amber lights turned on for a while when I'd hit the brakes (I think that's what you're saying). Ended up being a bad headlight switch from what I remember.
Old February 5th, 2016, 03:58 PM
Roverlab
Trevor Griffiths
Applying the brakes with a turn signal on, would cause the opposite front turn signal to illuminate.
I guess the resistors also act as a blocking diode, affecting current flow. Admittedly, I had forgotten that this kit did not come with any resistors and it slipped my mind.....glad I had some laying around for another job and was able to prove it out!
Email is
Old February 5th, 2016, 04:10 PM
The trailer converter is back-leaking voltage to the turn signals. The resistor drains that off enough that the LED can't turn on. LEDs need a minimum voltage to start lighting up. The front is just turning on a bit before the rear. You really need a trailer converter without leaking diodes....
Old February 5th, 2016, 09:05 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
On mine, there is a shared ground for the in dash indicator bulb...if you remove the bulb it worked fine...so then I added the resisters on the two front units and put the bulb back...everything good...
America Runs on Dunkin'
Rovers Run on Diesel
2017 Range Rover L405 HSE TD6
2008 Range Rover HSE L322/MkIII - Gone but not forgotten
1988 D90 County RHD 2.5TD
2015 Porsche Cayenne TD
Old February 5th, 2016, 09:17 PM
The normal indicator light is connected to the power supply for each light and not to ground. When one side is powered, the indicator light grounds out through the other side. The problem is an LED should not leak through current, so the indicator light can't work properly.
Old February 5th, 2016, 09:42 PM
icnsltmfg's Avatar
icnsltmfg
1988 D90 RHD 19J
You are correct..the power side
ht
Baja Designs LED Lighting Ash The Vendors Loft 51 September 29th, 2016 01:09 PM
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
Lighting issue Sparky Defender Technical Discussions 4 December 29th, 2013 01:23 PM
LED auxiliary lighting nathanwind Defender Technical Discussions 50 May 28th, 2013 03:01 PM
LED Issue - Aussie style bjf Defender Technical Discussions 37 June 26th, 2011 11:03 AM
