LED Lamps on ECR BR110 - Page 2 - Defender Source
Old August 16th, 2006, 08:02 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The Perei LED lamps are not as nice. They are not sealed but will do the job. There is also some minor clearance issues on them for the NAS 90s (you have to slightly trim the black plastic base).
I put a set of those on my own truck a few months ago, but was not 100% happy with them, that is why we went with the new design.
Europa Spares in the UK also sells the Perei units.
They also have quite few less LEDs in each unit.
Email:
Old August 16th, 2006, 11:34 AM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
Yet another site that sells LEDs for series and defenders.
http://www.roverantics.com/index.htm
Old August 17th, 2006, 11:29 AM
ECR's Avatar
ECR
OK, We got the BR110 back yesterday and finished the LED install.
Below you will find the link to the parts used.
I suggest these LED lamps over the Perei units. They have more LEDs, are sealed and have a much better look and pattern. You can base you choice on cost though, both will work, one just a little better. I've installed both.
The fast flash issue is solved by a varibale load flasher that will plug into the stock Rover harness. Like part #CF13GL-02 in the link below, but they are avaibale from many sources.
This will work with a mix of LEDs and bulbs or just LEDs.
The only down side is that the "trailer flash indicator" on the dash will no longer work. I have yet to find a 4 pin variable load flasher. Your trailer lights will work correctly, but it just won't indicate on the dash. I consider it small price to pay.
http://www.superbrightleds.com/flashers.htm
http://www.flexible-lamps.co.uk/
Email:
Old August 17th, 2006, 11:44 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Whats the part number for your choice of led lights then?
nice work
JP
legend in my own mind
Old August 17th, 2006, 12:24 PM
ECR's Avatar
ECR
JP
Its the flexible lamp units I like, not the Perei units.
Here are some pictures of the differences:
First (white truck) the Perei unit, Looks too "LED" for me.
Second is the Flexible lamp unit (on the Yellow truck). more LEDs and better lens (more NAS looking).
Third is the view inside the Perei unit (you can see LEDs and the red lens looks cheap.
Forth is the Flexible lamp unit lens. It is water tight and has more "style" (IMO).
I know these pix don't show the detail but thought I'd try.
I'll have px of the 1993-1994 units in a few days.
ID:	6276   Click image for larger version
ID:	6278   Click image for larger version
Email:
Old August 17th, 2006, 12:27 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
I think Pendy was asking for the actual part # for the chosen lamp assembly...there are several on the site URL...by the way, how did you order them? their site doesn't have a clear path to purchase...
Old August 17th, 2006, 12:44 PM
ECR's Avatar
ECR
We get ours through our UK suppliers in the past... but "as luck would have it" we have just become a Flexible lamp US distributor and will have for sale their product line very shortly. Funny the timing on that heh???
So for now you have to order through a distributor, or wait for us to get inventory.
In the Mustang and Dune Buggy web boards I use they sometimes do a "group buy". This is done so prices can come down for those on the board.
I'd be happy to do some sort of "group buy" discount to get these out there to folks as I know it is a good solution.
If that is "too commercial" for the board I understand. Maybe the moderators can suggest a solutiuon?
I feel inclinded to mention for those that are completely paranoid, that these lamps are not DOT labled.
Email:
Old August 17th, 2006, 01:03 PM
Chaucer
Will
93 110 | 97 90
If I had to guess, I'd say Mike's probably looking at one of these:
http://www.flexible-lamps.co.uk/Cata...oducts/837.htm
http://www.flexible-lamps.co.uk/Cata...oducts/838.htm
http://www.flexible-lamps.co.uk/Cata...oducts/810.htm
Perhaps this one for the earlier Defenders:
http://www.flexible-lamps.co.uk/Cata...oducts/313.htm
Old August 17th, 2006, 01:07 PM
ECR's Avatar
ECR
The 837s are the "NAS" style
Sorry, I misunderstood the question.
Email:
Old August 17th, 2006, 01:37 PM
Rob
rob
1997 D90
Dumb question - where does the variable load flasher actually plug in??
Old August 17th, 2006, 01:49 PM
ECR's Avatar
ECR
You remove your factory flasher (from behind the fuse cover) and install the new one in the same location. It plugs in the same socket. Its a remove and replace operation.
Email:
Old August 17th, 2006, 02:19 PM
Rob
rob
1997 D90
which one is it of the 7 or so that line up across?
Old August 17th, 2006, 02:27 PM
ECR's Avatar
ECR
It is the black unit behind the metal fuse panel (it isn't in that bottom row of relays). It isn't really visible until you pull it out. If you want to find it turn on your hazards and hunt down the "clicking" noise in the fuse box area. Its right next to the fuel pump inertia cut off (on 1993-1995s).
Email:
Old August 17th, 2006, 02:42 PM
Joe P's Avatar
Joe P
Joe Pfeiffer
Black 97 D-90ST #0605
Will these work with the same variable load flasher on the 97's, or just the 93-95's.
If the truck makes it - the trail wasn't tough enough.
If the truck doesn't make it - the truck wasn't tough enough.
Old August 17th, 2006, 04:12 PM
Mike - if it makes you feel better, I can be the "group buy" point of contact. I'm on the left coast, but you could make one shipment to me and I'll break them out for everyone else. I have a FedEx account so shipping can stay reasonable. Keeps you out of the mail order biz and keeps you from walking the "commercial interests" line.
Old August 17th, 2006, 05:17 PM
ECR's Avatar
ECR
Yes, same unit does all.
I said 1993-1995 as I mentioned the relation to the fuel pump cut out switch, and the 1997 does not have that in that location and I just knew some "detail guy" would have to point out I was wrong if I said 1993-1997.
Email:
Old August 18th, 2006, 02:35 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
This will take care of one side (the left side, I think) but what about the other side, the one without the reverse lamp? Any ideas?
Also, does anybody have a source and part number for an LED replacement for the small round "beehive" lights that sit next to the headlights, two-to-a-side?
UPDATE: Here's some replacements for the front beehive lamps but OUCH, $19.50 apiece!
http://www.ledtronics.com/ds/AUT67/d...sp#15mmbayonet
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old August 21st, 2006, 02:50 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Mike -- just read the thread on #157 -- did you convert the back panels to fit the round lights? For some reason I seem to remember that one couldn't directly retrofit the round lights to '93 110s or '94 90s.
Old August 21st, 2006, 03:18 PM
ECR's Avatar
ECR
Unknown about panel issues, as the rear tub on #157 was replaced with new and it had no holes in it so we had a blank slate to start with when installing the lights, but the main reason I recall that the round 95-97 style lights haven't gone many of our 110s in the past is that the depth of the stop/tail light would go in and stab the roll cage support making the set up not fit, but the LED units have no depth so that is not an issue anymore.
Email:
Old August 21st, 2006, 03:46 PM
Gkase's Avatar
Gkase
George Kase
Mike, if you do a kit...let me know...
110, ecr, lamp
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
WARNING for those with ECR LED tail lamps ECR The Vendors Loft 39 March 3rd, 2011 09:09 AM
Packing the Hub bearings sflash868 Defender Technical Discussions 11 May 22nd, 2008 03:32 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
ECR BR110 door panels artm Defender Technical Discussions 1 August 9th, 2006 10:46 AM
