LED Issue - Aussie style - Defender Source
Old June 2nd, 2011, 12:12 AM
bjf's Avatar
bjf
barry f
94 ST #395
So I ordered replacement LED bulbs from the bushman figuring, if it is done in the bush it has to be right. Got my order today and I figured it was as good a time as any to replace my dash cowl.
For the most part it all went as planned. Getting two of the dash cowl screws out sucked but everything else was ok. First thing I notice when I am working on my bulbs is my heat and fan lights aren't going on. I don't get this because I didn't mess with the bulbs. The second thing I notice is the tach uses a different bulb than everything else.
So my two questions:
Was the aussie wrong that all the bulbs are the same
and
Why would the heat and fan lights not work?
Pics coming in one sec
Old June 2nd, 2011, 12:13 AM
bjf's Avatar
bjf
barry f
94 ST #395
Pics
ID:	39276   Click image for larger version
Old June 2nd, 2011, 01:20 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
The tach is indeed different. I ordered a replacement for it from superbrightleds.com
I am not sure about the others, but if you didn't touch them I would start with the most obvious...a fuse or a ground
Old June 2nd, 2011, 01:23 AM
CDeWan
Clay DeWan
5.3L beastie
Andrew,
Do you have the part number from Superbrightleds.com for the tach light and the rest of the guage lights? Do tell.
------ Follow up post added June 2nd, 2011 01:28 AM ------
Barry,
I heard Josh met some bushmen (bushmen not into "bush" man!.au.com) in a chat room that worked for the light company that you ordered from and sabotaged your order. This was posted on his "get even with Barry Wall".
So the bushmen that are not into "bush" man which now Josh is part of, are behind this conspiracy.
Old June 2nd, 2011, 01:31 AM
bjf's Avatar
bjf
barry f
94 ST #395
Andrew
Found your thread
http://www.superbrightleds.com/cgi-b...ecs%2Fba9s.htm
That is the tach. Going to order tomorrow. Can't figure out why every other bulb would work but those two don't They are such tiny bulbs I can't see why everything else works and they don't. Wonder where the ground would be.
Old June 2nd, 2011, 01:37 AM
CDeWan
Clay DeWan
5.3L beastie
Wonder where the ground would be.[/QUOTE]
Ah, beneath the truck and your feet.
On a less serious note you could see if the flimsy circuit board that the plugs for the warning lights go onto are a little worn and spray some electrical cleaner and possibly put some di-lectric grease on the plugs.
Old June 2nd, 2011, 02:19 AM
bjf's Avatar
bjf
barry f
94 ST #395
This is the fan bulb and hot cold bulbs though.
Old June 2nd, 2011, 01:21 PM
bjf's Avatar
bjf
barry f
94 ST #395
Anyone know the LED equivalent of this http://www.roversnorth.com/store/p-5...er-swtch-.aspx
Old June 2nd, 2011, 02:28 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
I believe the equivalent is the 74x from Superbrightleds.com
Old June 2nd, 2011, 02:33 PM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
It looks like the 74-x. Its only $1.19 each. How many bulbs do we need on the instrument panel, etc...?
Old June 2nd, 2011, 02:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
Ordered thanks
Old June 2nd, 2011, 11:08 PM
bjf's Avatar
bjf
barry f
94 ST #395
Got it all working again. Of course while working on it I broke the white plastic bulb holder for the fan. Does anyone have one or know the part number?
It is white plastic, holds the bulb and has two prongs on the back for the wires to go to.
Old June 3rd, 2011, 01:15 AM
bjf's Avatar
bjf
barry f
94 ST #395
Before and after. Still need to do the tach
Old June 3rd, 2011, 01:18 AM
bjf's Avatar
bjf
barry f
94 ST #395
Pics attached this time
ID:	39335   Click image for larger version
Old June 3rd, 2011, 03:19 AM
CDeWan
Clay DeWan
5.3L beastie
Holder
I have one but it is gonna cost you buddy! PM me your address and as usual I will send it to you but I am slow on the shipping part cause my work sucks!
P.S. I am writting this while still at work at 12:18 in the morning.
Old June 3rd, 2011, 10:14 AM
rover26c's Avatar
rover26c
Lee
1994 D90 ST
74-x is the part number from Superbrightleds.com for the tach light and the rest of the guage lights? Please confirm. Thanks.
Old June 3rd, 2011, 10:30 AM
bjf's Avatar
bjf
barry f
94 ST #395
No the 74 bulb is just the fan. If you search led you will see all the correct bulbs.
There is one kind for the speedo, fuel, and temp and another kind for the tach and finally another kind for the fan and heat controls
Old June 3rd, 2011, 11:09 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
As I recall, the clock is different as well, at least on the 110. I think Barry already linked my thread that detailed all the bulbs and what they fit.
Old June 3rd, 2011, 06:43 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Sounds like you already ordered but 74x-HP is much brighter. The Bushman would be jealous.
Old June 3rd, 2011, 06:51 PM
bjf's Avatar
bjf
barry f
94 ST #395
Seems bright. Didn't have to widen hole
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
Packing the Hub bearings sflash868 Defender Technical Discussions 11 May 22nd, 2008 03:32 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
