LED Issue - Aussie style - Page 2 - Defender Source
Old June 3rd, 2011, 07:03 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Where's this fan light you're talking about? Next to fan lever?
Old June 3rd, 2011, 07:06 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yes the fan controls and vent controls. Little white plastic thing hold bulb
Old June 3rd, 2011, 11:09 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Do you have the upgrade fever yet Barry? What's next? VDO gauges? Side markers? Turn signals?
------ Follow up post added June 3rd, 2011 10:10 PM ------
Thanks for the tip. I don't think these have ever worked on mine. I will stick some new bulbs in there.
Old June 4th, 2011, 07:29 AM
Boy I love my VDO gauges one of the only worthwhile mods I have made
Old June 6th, 2011, 10:46 PM
bjf's Avatar
bjf
barry f
94 ST #395
This is the piece I need. Pay no attention to the bloated corpse hand
Old June 7th, 2011, 06:54 PM
bjf's Avatar
bjf
barry f
94 ST #395
No one has this?
Carl
I did notice I didn't need to bend anything when I helped Mark put his LEDs in. Oh well. I guess being safe wasnt a bad thing.
Old June 7th, 2011, 08:45 PM
Reese_D90's Avatar
Reese_D90
Reese
97 D90 ST and 93 D110
I think RDS has them
NAS 1993 D110 CDN #11/25
1997 D90 ST #1953
2006 Range Rover
1997 D90 SW #701 (sold)
1995 D90 ST (sold)
Old June 13th, 2011, 04:26 PM
bjf's Avatar
bjf
barry f
94 ST #395
Finally got them all in. Dare I say too bright especially fan switch.
Old June 13th, 2011, 06:35 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What bulbs did you get for the fan? From Superbrightleds?
Yeah, the only bulbs the needs modification are the SW rear wiper/defroster controls. Mine fried so I freaked and trimmed every wedge bulb i had only to discover it wasn't necessary. Still have to replace the fried wire. It's part of the main harness so that ought to be fun.
Old June 13th, 2011, 06:39 PM
bjf's Avatar
bjf
barry f
94 ST #395
Yeah from superbrightleds. I went with the 360s. They work well just not used to the green hulk glow. I am so sick of pulling the dash apart that they will stay for a bit. Replaced the fan and hot cold controls too.
Old June 13th, 2011, 07:01 PM
Broncoduecer's Avatar
Broncoduecer
peter
D90
If you find it let me know. I as well need one of those little guys. Might take a handful just in case....
Old June 13th, 2011, 07:14 PM
bjf's Avatar
bjf
barry f
94 ST #395
I ended up fixing mine with some plastic glue. Can't think of the brand but you rub a marker on then dab the glue. It came out perfectly. Since this piece hold no weight it worked fine. If I find a replacement I will let you know.
Old June 16th, 2011, 12:47 PM
Broncoduecer
peter
D90
Sounds like a plan! I was thinking of the glue route until then also.
Old June 26th, 2011, 09:34 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I just replaced all my dash gauges for VDO and I noticed that I don't have lights for fan/vents. Nowhere to be found. How are those wired? Are they on their own or are they wired in with one of the dash gauges?
Old June 26th, 2011, 09:50 AM
bjf's Avatar
bjf
barry f
94 ST #395
Separate wires. You don't have the plugs just hanging out back there?
Old June 26th, 2011, 09:58 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I found one of them. It was wired in serially with the tach light but I removed it and made the tach have a light on it's own. That way if one fails both don't go out. The fan control light is gone and the one I did find is broken. Not sure it's worth the effort to source and wire in two new ones.
Are they part of the stock rover instrument harness (has yellow label on it)?
I did notice that the socket holder for the one I did find is similar to the SW dash button bulb holders which would mean you could short it if you switch to LED.
Old June 26th, 2011, 11:01 AM
bjf's Avatar
bjf
barry f
94 ST #395
I would assume it is all part of the stock harness. I have seen it in my 94 and mark's 95.
Old June 26th, 2011, 11:03 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Hmm. Strange. There are no orphan wires in my stock instrument harness. The one I found was attached to the tach. Somebody must have messed with it. Mines a 95 NAS as well.
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
Packing the Hub bearings sflash868 Defender Technical Discussions 11 May 22nd, 2008 03:32 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
