LED install issue: Please Help - Defender Source
Old January 15th, 2018, 07:29 PM
D90rovin
95 NAS SW
Installing new LED lights to replace my old stock lights on a 95 NAS.
Turn signals work, hazards work, reverse light works
Everything went smoothly until I check my tail light. I can have my tail light on OR brake light but not both working properly. Iím speaking singular because Iím still waiting delivery on one of the LED taillights. If I switch the one that I have to the other side, same scenario.
Iíve searched the threads but donít see my exact scenario so what am I messing up?
Old January 15th, 2018, 07:38 PM
Two possibilities. One you have a bad ground on those lights. They share the same ground and when it is poor, the lights ground through the other one.
Two, you have it wired wrong. The wire colors usually are wrong on the new lights, so you must check them first.
Old January 15th, 2018, 08:04 PM
D90rovin
95 NAS SW
John,
Thank you for chiming in. Is there a standard location for NAS models where the tail lights are usually ground at?
Iíll quadruple check the wiring as I thought that might have been it after reading some posts but when I change the wires I only get three options.
1) no light
2) tail light on (low light)
3) brake light on (intense light)
Old January 15th, 2018, 08:21 PM
Go over all of the black wires in the back and give them all a good tug on the connectors to make sure there are no loose wires or bullets that are loose. I'm no expert on the NAS wiring. My trucks have ground to the body under the wiring covers in the back, plus there is a ground that runs up the loom.
Old January 20th, 2018, 03:48 AM
D90rovin
95 NAS SW
update
Got this all sorted. I just double checked the wiring and cleaned the connectors really well. Wired up and they work fine; much brighter and Iím glad the new units are waterproof.
Thanks John
Terrafirma Rear Shock Install Issue mgrgpg Defender Technical Discussions 4 December 6th, 2017 03:38 PM
1997 NAS D90 Indicator LED Lights issue MotoMando Defender Technical Discussions 3 September 3rd, 2017 07:14 PM
LED Bulb Issue kevkon Defender Technical Discussions 4 July 21st, 2011 07:54 AM
LED Issue - Aussie style bjf Defender Technical Discussions 37 June 26th, 2011 11:03 AM
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
