LED Indicator Lights - Defender Source
Old April 13th, 2014, 09:59 AM
jpm
Jim
88 110
Just installed new LED's all around. All 4 indicator lights flash regardless of turn signal position (left or right). Saw the earlier post on this and I do have an adjustable relay. Just added 2 resistors to the front indicator lights and they all still flash. Do I need to add two more resistors to the rear indicator lights? This seems like a belt and suspenders? Thanks for any help.
Old April 13th, 2014, 10:17 AM
This is nothing to do with resistors
Remove the front resistors. The variable relay takes care of that requirement. Sounds like an issue with the hazard switch. Gently pull it towards you. They get a bit sticky and don't release properly and no doubt you've pressed it testing the lights.
Old April 13th, 2014, 10:34 AM
jpm
Jim
88 110
No Joy
Thanks Jason, but I just removed the resistors and gently pulled the hazard switch to no avail. Perhaps a bit more force, say a 10 lb sledge, might be better? This isn't rocket science, but clearly I'm too close to the problem to see a rational solution.
Old April 13th, 2014, 11:14 AM
No problems before the switch to LEDs?
Step at a time with electrickery:
To confirm the relay is working correctly, put the old one back.
If no change, then we also know that the problem is elsewhere.
Any other electrical work performed at the same time?
Old April 13th, 2014, 11:34 AM
NPT90's Avatar
NPT90
JT
D90 óriginalé
This might be a long shot but perhaps your black and red are reversed; meaning for some reason your common going back is hot and your hot goes to ground... Maybe something in the harness, hook your meter up and see if the polarity is reversed with the lights on
Edit this is probably incorrect having read the symptoms in more detail but I'd still check. Sounds like some interesting wiring might be causing your headache
Old April 13th, 2014, 11:38 AM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
My issues with LED installs were with jerry rigged wiring by the previous owner and incorrectly wired Wipac LEDs from the factory.
Old April 13th, 2014, 11:40 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
^^ what he said ^^.
Incandescent bulbs are not dependent on polarity to work. However LEDs (D as in diode) are.
NPT90's Avatar
NPT90
JT
D90 óriginalé
It's funny, it's a good sign that they turn on at all hahaha
Old April 13th, 2014, 11:41 AM
snowpup's Avatar
snowpup
Jeff Snow
1997 D90
I had a similar issue. See thread: http://www.defendersource.com/forum/...ad.php?t=51910. I had the adjustable relay and was not supposed to need resistors all around. That did not work. I added resistors all around and it worked like a charm. Not sure why - could be magic. The link to the resistors I used is in the thread. good luck.
Old April 13th, 2014, 11:48 AM
Mybluett's Avatar
Mybluett
Defenders Northwest
110SW
Do you have marker lights hooked up or LED there as well?
Usually markers are enough resistance when used with the adjustable relay.
Old April 13th, 2014, 11:50 AM
snowpup's Avatar
snowpup
Jeff Snow
1997 D90
that could have been my issue, because I have LED bulbs in my marker lights as well.
Old April 13th, 2014, 12:14 PM
jpm
Jim
88 110
Mybluett solved the problem. One of my marker light bulbs was not working!!! Fixed the bulb and all is well in the world. Thanks to all for their thoughtful suggestions.
ht, lights
Brake, indicator and reverse lights Baldewin For Sale - Parts 3 May 22nd, 2013 11:50 AM
How to Convert 1994 rear Square Lights to 95-97 LED lights FlaD90 Defender Technical Discussions 7 November 20th, 2011 05:34 AM
LED side indicator lights kellymoe Defender Technical Discussions 0 August 27th, 2009 12:41 AM
LED side indicator lights kellymoe Misc. Chit-Chat 0 August 27th, 2009 12:41 AM
top warning/indicator lights not working draaronr Defender Technical Discussions 2 May 22nd, 2008 07:43 PM
