LED Headlight Issue - Defender Source
Old June 5th, 2016, 11:45 AM
87 D110 (Ruby)
LED Headlight Issue
OK - all you electric gurus....
My LHS LED light doesnt work on normal beam (I get 0.03 on meter) but it does on the high beam (I get ~12 on meter)...and both top and bottom LED lights come on when I flick to high beam. So, it isnt an issue with the light.
Could it be the headlight switch? I dont have a relay (that I know of) to the switch....and I dont have another switch to test it with.
Thoughts?
Old June 5th, 2016, 11:51 AM
I had this same issue a few weeks back. It turned out to be dirty contacts in the switch. Contact cleaner and compressed air took care of my issue.
Old June 5th, 2016, 11:52 AM
87 D110 (Ruby)
Cheers Dave - it just happened - so I wasnt sure. Ill pull it and clean it.
OK - BUGGER....now what?
I pulled the switched, cleaned contacts, fired it - no go - so I jumped the brown and blue wires on the switch....RHS light fires up. Nothing on LHS?????????????? Anyone with a wining solution?
Old June 5th, 2016, 05:49 PM
carlosz's Avatar
carlosz
Carlos
headlights have independent L and R fuse for safety reasons. if you are not getting power at headlight check fuse, make sure headlight is not culprit.
all checks ok, check switch, switch ok suspect combination switch (hi, lo turn)
follow diagnosis flow chart, last but not least do not overlook your grounds.
Old June 5th, 2016, 06:01 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
I'm just spitballing here but, if the low beam fuse for that side is okay, have you checked the polarization of the low beam wiring? This should be a pretty simple diagnosis with a meter.
ht
Hot headlight relay, brake light issue... RX6RCROL Defender Technical Discussions 5 March 22nd, 2016 03:28 PM
Trucklite LED headlight issue Paul K Defender Technical Discussions 21 January 17th, 2016 07:52 AM
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
KC HiLiTES - 7" LED HEADLIGHT SET rtgoldenb Defender Technical Discussions 17 November 22nd, 2014 11:36 AM
Headlight Switch Issue, any ideas? januconn92 Defender Technical Discussions 1 July 24th, 2005 11:53 AM
