LED for turn signals, defender - Defender Source
Old December 12th, 2017, 04:30 PM
fastinjun's Avatar
fastinjun
Mitch
Ok, previous owner replaced the stock bulbs with LEDs for the turn signals but they seem to be really dim then eventually get brighter the longer they are flashing. Im guessing they need a relay ? do I replace the factory flashing unit??
Old December 12th, 2017, 07:11 PM
east high's Avatar
east high
Gerad Davis
1967/s2a 88 200Tdi
I had to replace the factory flasher with a electronically controlled one when I switched to LEDs. There's not enough resistance to make them work. You might also have to wire in a resistor to the signal circuit to regulate the flashing or else they'll blink too quickly.
These are what I used:
https://www.superbrightleds.com/more...asher/780/834/
https://www.superbrightleds.com/more...g-fix/190/831/
Old December 12th, 2017, 08:54 PM
Sounds like you probably have a ground issue. Start there. It might tell you more about what other mods he did to the wiring..
defender, signal
LED Turn Signals brettm Defender Technical Discussions 13 October 24th, 2013 09:28 AM
Flasher Unit LED turn signals rustydefender Defender Technical Discussions 2 November 14th, 2006 09:28 PM
1994 Red Defender 90 for sale BrianConway321 For Sale - Vehicles 5 February 22nd, 2005 09:27 PM
