LED Flasher part number - Defender Source
Old June 13th, 2007, 01:09 PM
sea2sumag
Sean Gorman
1994 D-90 300 TDI
Does anyone know what flasher unit I need for LED tail lamps? I think there is a common, and easily available unit.
Thanks, Sean
Old June 13th, 2007, 01:30 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
They are available pretty much anywhere, just make sure it's labeled "Electronic Flasher", and it should have the IC timer circuit inside instead of the older bimetal resistance switch.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 13th, 2007, 02:54 PM
RyanS's Avatar
RyanS
Ryan
'93 NAS 110
I got a Tridon EP36 electronic flasher at Autozone. It's a 3-pin flasher. If you need a 4-pin (I believe the 4th pin is for trailer output), get the EP26. I've also seen them at Pep Boys so they're probably available at most of the major auto parts stores.
Old June 13th, 2007, 07:13 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Thanks, Sean
www.superbrightleds.com
- Charles Eames
part
Part Number for AC Idler Pully mgrgpg Defender Technical Discussions 2 August 4th, 2005 10:07 AM
Part number for 300tdi D90 steering wheel? dmarchand Misc. Chit-Chat 12 June 22nd, 2004 10:28 AM
Lucas problem; need part number sherpamike Defender Technical Discussions 4 May 26th, 2004 10:27 PM
Part number for genuine roof rack? wicks Defender Technical Discussions 13 March 3rd, 2004 06:34 PM
Part Number Cross Reference Database mlepisto Misc. Chit-Chat 8 December 19th, 2003 12:52 AM
