LED Conversion - Defender Source
Old December 12th, 2015, 07:00 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
LED Conversion
Hello,
I am planning to convert the exterior lights on my 1988 110 to LED. Wondered if anyone had any feedback on the process and the best manufacturer to source the lights from.
Ben
Old December 12th, 2015, 07:12 PM
Paul K's Avatar
Paul K
Paul Kennington
'85 Ninety V8 SW
I did that to my '85. Defenders NW had a special on the kit. I still have a problem with the rate changing when the brake light is on (barely noticeable) but that will be remedied when I re-wire the lights during the new chassis job. I've been very happy with the lights. I swapped the bulbs out on the fender-mounted turn signals also. I know Rovers North sells the kit also.
Good luck!
Current fleet: '85 Ninety 3.9 V8i Auto SW, two Discovery 1's (one for my Nephew, one for my Niece),'07 BMW 335Xi.
Old December 12th, 2015, 07:16 PM
There are a bunch of thread on this subject. Best to search.
There are four different options.
Old December 12th, 2015, 07:19 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Great - thanks very much
------ Follow up post added December 12th, 2015 07:26 PM ------
Paul,
When you did your LED conversion did you think about adding the rectangular LED's that fit into the front bumper? Trying to decide whether they would look tacky.
Ben
Old December 12th, 2015, 08:03 PM
carlosz's Avatar
carlosz
Carlos
Ben once you have all four corners turn signals led's they will hyper flash.
solution # 1 leave at least one regular bulb on each side.
solution # 2 replace the flasher relay with electronic unit made for led lighting.
solution # 3 wire resistors on every circuit to fool the circuit into thinking there is regular bulb.
led's do not load the circuit as it was designed, thus the last two solutions.
Old December 12th, 2015, 08:21 PM
koltonstanley's Avatar
koltonstanley
Kolton Stanley
defender 130 hi cap
there are a bunch of diffrent options.
I just did my entire truck with a kit i bought of EBAY UK from bolt on bits.
they sell NAS and Row LED light kits....in just about every combination you can think of.
they also come with the LED adjustable resistor thing that makes them all flash perfect.
was super easy....plug and play..
Old December 12th, 2015, 08:28 PM
mpodgorski's Avatar
mpodgorski
martin
'94 D90 ST Arles
Originally Posted by koltonstanley View Post
there are a bunch of diffrent options. I just did my entire truck with a kit i bought of EBAY UK from bolt on bits. they sell NAS and Row LED light kits....in just about every combination you can think of. they also come with the LED adjustable resistor thing that makes them all flash perfect. was super easy....plug and play..
Funny to see the same area missing paint as mine had. When I first removed the top it took the paint off the cabs roof edge.
Old December 12th, 2015, 08:39 PM
koltonstanley
Kolton Stanley
defender 130 hi cap
Originally Posted by mpodgorski View Post
Funny to see the same area missing paint as mine had. When I first removed the top it took the paint off the roofs edge.
Attachment 136897
HA yea thats pretty funny.......
I had another pickup before this one and im pretty sure the paint was chipped at that same spot on that truck too....
Old December 12th, 2015, 08:45 PM
Ben Dutton's Avatar
Ben Dutton
Ben Dutton
1988 Land Rover 110
Thanks very much everyone for the advice - it is great to get feedback from others who have done this.
Old December 12th, 2015, 08:49 PM
grnrvrs's Avatar
grnrvrs
Paul
88
I have Wipac leds with their adjustable flasher and I'm quite pleased with them.
1970 SIIA 88, Sold
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
led taillight conversion BadMonkey Wanted 9 November 11th, 2011 01:02 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
