LED Bulb Issue - Defender Source
Old July 20th, 2011, 02:45 PM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
LED Bulb Issue
Ok, I know there are a million posts on the LED issue, but I don't remember seeing any on this, radio interference. I had swapped out all the bulbs on my 94 for LEDs ala Superbright and after sorting out the issue with the front turn signals, all was fine. However, I have been getting a strong interference on my radio whenever I use the brakes. Since I had done nummerous other things on the truck during this period, my first thought was the solonoid on the shift interlock ( ZF Trans) which engages withg the brake switch. So yesterday I removed it, started the truck, turned on the radio, depressed the brake pedal and the interference was still present. Today I removed the 1157 LEDs in my taillight and put back the original incandescents and guess what?. No more interference. Has anyone else had this issue?
Old July 20th, 2011, 02:49 PM
interference is usually an issue with grounding/ earth. I'll bet your radio shares a ground. give it a dedicated solid ground and I'll bet it goes away.
Mark Kellgren
KM4BOR
Old July 20th, 2011, 02:55 PM
kevkon's Avatar
kevkon
kevin
It does have a dedicated ground, that's what is strange.
Old July 21st, 2011, 03:54 AM
TS888's Avatar
TS888
Tony Sims
1984 110
Your truck is quiet enough to hear the radio? While it's running?
Tony
1984 110 "Smokey" (sold)
Old July 21st, 2011, 07:54 AM
kevkon's Avatar
kevkon
kevin
I wouldn't go so far as to say it's quiet, but I certainly don't have a problem with hearing the radio.
So, anyway I found the problem. I had a couple spare 1157 type LEDs and I swapped them. Finally found that only one of the bulbs was causing this interfernce. No idea why.
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
LED Issue - Aussie style bjf Defender Technical Discussions 37 June 26th, 2011 11:03 AM
Help! Wire and bulb melted during an attempt to upgrade to LED. Manimal Defender Technical Discussions 5 July 12th, 2010 11:33 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
Side lamp bulb holder Neo Defender Technical Discussions 5 January 30th, 2004 05:07 PM
» Defender Registry
D90
NPT90
Tippy
K2atlanta
Add your Defender
