LED brake light problem - Defender Source
Old October 17th, 2014, 09:58 PM
Freeser
Tom Freese
1988 110
I installed WIPAC LED brake/tail lights and turn signals a couple of months ago. After having to check and fix tail lights every time it rained I was happy to switch to LEDs. Everything has been working fine until today. For some reason the brake lights decided to go crazy. When I put my foot on the brake sometimes the brake lights come on and work normally. Other times when the brake pedal is pressed nothing happens. The strangest thing is that the brake lights blink almost like a strobe light sometimes when the brake pedal is pressed. The turn signals and tail lights still are working normally. Both brake/tail lights do the same thing so I don't think it has anything to do with the LEDs or the connections in the back. Any thoughts?
Old October 17th, 2014, 10:09 PM
DannyboyUpstate's Avatar
DannyboyUpstate
Danny Harrington
1983 110 3-door
LEDs need an adequate voltage or they won't work at all. It won't be dim like a regular filament type light bulb. I would bet you have a bad ground or a high resistance wire. Check the output voltage right at the bulb with a good meter.
Old October 17th, 2014, 10:12 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Check your grounds. The rear lighting ground is on the right side and should be attached to the tub somewhere. Your turn signals and running lights go through the same ground. I have had no electrical problems with mine after going through all the grounds and fuse box connections. Possible your brake light switch is failing too.
Ryan
84 110SW County LHD
07 L322 Vogue
Old October 17th, 2014, 10:15 PM
I was thinking this too...BUT, isn't each side grounded separately? So you'd expect one side to be squirrelly with a bad ground - not both in unison?
Old October 18th, 2014, 05:43 AM
DannyboyUpstate
Danny Harrington
1983 110 3-door
If they're both separately grounded than I'd believe you're correct.
On my truck there's a single 12VDC leading to the rear brake lights that ends at a bullet connector. Then both brake lights are run in parallel off of that. So it's possible that 12VDC from the front of the truck is pinched/corroded and it's causing a voltage drop to the rear of the truck.
Old October 18th, 2014, 08:15 AM
Wondering of the brake pedal switch is having issues.
Old October 18th, 2014, 01:22 PM
Freeser
Tom Freese
1988 110
I'll check the ground. how do I access brake pedal switch to check that if the ground is OK?
Old October 18th, 2014, 01:47 PM
The brake pedal switch is at the top of the brake master cylinder. It should have two wires plugged into it. One that is hot whenever the ignition is in the "run" position and the other that runs to your brake lights. Unplug them both and jump one to the other. If your lights work you have a switch issue that is easy to swap out. If they still act funky you have a wiring/ground/bulb issue.
Old October 21st, 2014, 07:07 AM
flananuts
Matthew
LRC Customs #003 D110 Soft Top
I would suggest using a meter at the switch to verify the switch is functioning. Then you'll have a clearer idea of what to do or where to look next.
brake, ht
LED third brake light. Crash303 Smaller Projects 15 October 26th, 2016 10:11 PM
Parking Brake and Rear brake light gas-man Defender Technical Discussions 9 February 20th, 2012 11:40 AM
Rusty soft top third brake light bar and light evilfij Wanted 2 May 20th, 2009 11:26 AM
Brake light on after brake install wicks Defender Technical Discussions 6 October 13th, 2003 07:01 PM
