LED Brake and Running light - light out on - Defender Source
Old February 2nd, 2016, 04:05 PM
CDeWan
Clay DeWan
5.3L beastie
Anyone running into the "bulb light out" on the dash when they switch to brake/running LED's?
Old February 2nd, 2016, 04:10 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
http://www.amazon.com/Resistors-Sign.../dp/B004EDF8HY
Me know understand question??
Old February 2nd, 2016, 04:35 PM
CDeWan
Clay DeWan
5.3L beastie
fix the problem
Originally Posted by NPT90 View Post
Jt these look inline and easy to do. Should fix the problem?
Old February 2nd, 2016, 04:37 PM
That depends....
You said "Anyone running into the "bulb light out" on the dash when they switch to brake/running LED's?"
Those resistors are to fix a turn signal light problem and have nothing to do with brake and running lights. The resistors are poor fix, IMO. You should get the correct flasher relay.
What is your actual problem?
Old February 2nd, 2016, 04:38 PM
CDeWan
Clay DeWan
5.3L beastie
brake light LED tail light
Anyway I don't get a bulb out on the idiot cluster on the dash until I turn the light switch either to forward either parking or all the way on.
The bulb out light will come on, so my rationale is that the LED brake/Running lights are not pulling enough current so it makes it makes the bulb out light come on.
It does beg to ask why doesn't the bulb out come on when apply the brakes only and the parking or running lights are not on?
Hmmm.
Old February 2nd, 2016, 04:47 PM
Hmmm.
There is a bulb light out indicator?????
Old February 2nd, 2016, 05:23 PM
I have no clue what he is talking about.
Old February 2nd, 2016, 05:43 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
He could be getting a backfeed through a ground or it could be the trailer light. Mine used to blink when I had a light out (I think it's resistance based)
Old February 2nd, 2016, 06:16 PM
If there is a bulb out indicator lamp, I would just remove its bulb. It won't work with the LEDs.
Old February 2nd, 2016, 06:19 PM
Those connectors just invite corrosion
Old February 2nd, 2016, 06:22 PM
You don't have to use those connectors....
Who would want to purposely add 100W of load to your electrical system? Defeats the whole point of using the LEDs!
And the burnt bulb indicator will turn off, but it won't ever indicate when a bulb is burnt out. All you have done is add a bunch of load to the system. Remove the bulb....
Old February 2nd, 2016, 08:00 PM
You don't...and you shouldn't!!! Just wanted to make sure that was clear since LED issues are prevalent and sure it may work short term but with scotch locks you'll have even worse issues (likely) shortly down the road.
Old February 2nd, 2016, 08:03 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
1000% agree those connectors are garbage.
Old February 2nd, 2016, 08:19 PM
I dream of the day I find wiring done by an owner that is done properly.
Old February 2nd, 2016, 08:54 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
a unicorn
Old February 2nd, 2016, 08:57 PM
lol...i asked myself the same question
Old February 2nd, 2016, 09:01 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
my trailer light used to Bing when I had a light out, not sure if this is common or not
Old February 2nd, 2016, 09:23 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Oh, you mean with wire nuts?
-Jeff
I think he means good old british chocolate blocks
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 2nd, 2016, 09:27 PM
Better than wire nuts. But then I grew up with the Cadbury connector so it's what I like best.
brake, ht
LED third brake light. Crash303 Smaller Projects 15 October 26th, 2016 10:11 PM
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
Left rear brake Light Out, and I mean Out! RickM Defender Technical Discussions 6 December 8th, 2004 09:31 PM
