LED Brake and Running light - light out on - Page 2 - Defender Source
Old February 2nd, 2016, 09:29 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
Originally Posted by Rocky View Post
Better than wire nuts. But then I grew up with the Cadbury connector so it's what I like best.
Ditto
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
Old February 2nd, 2016, 10:21 PM
There is a bulb light out indicator?????
Can we go back to this question above...honestly, there can't possibly be a "bulb light out" indicator light on the dash...can there???
Old February 2nd, 2016, 10:59 PM
Maybe CDeWan can provide a picture. Maybe it is NAS90 specific??
Old February 3rd, 2016, 06:33 AM
CDeWan
Clay DeWan
5.3L beastie
Sure can. But lets say it is a warning light below the high beams.
Now I did replace the circuit board behind the light cluster (flimsy plastic one) so it could be that I did not replace it with the right part or NAS part.
I will take a pic.
I was assuming and you know what happens during assuming that this is a light out light as it is the green box.
It may be better as suggested to just remove the bulb as it could be telling me nothing and I don't run into this problem with my NAS 94 when a light is out.
Like mentioned, maybe the takeaway is to pull the bulb. Or leave it in and say "hey that light is telling you the light switch is on".
Old February 3rd, 2016, 06:45 AM
CDeWan
Clay DeWan
5.3L beastie
wiring
Jon,
in the case I can assure you that the wirng waaas dun to the beast of my ablities. I grounded everting fist and them waitd for blowin fuses yuch yuck!!!
Actually this was the cleanest wire job I have done. No shortcuts, cut wires or left out wiring boxes/dingers etc. The LED brake/running lights conversion was because when using a 94 roll cage rear tub supports, you can not use a 95 round bulb as it is too deep and will not fit flush as it will butt up against the crossmember to tub support, thus the low profile of a LED will fit in that space. 95/97 have a different tub support which allows for the clearance of the back side of the bulb/plug in connector.
Originally Posted by Red90 View Post
I dream of the day I find wiring done by an owner that is done properly.
Old February 3rd, 2016, 07:33 AM
I will take a pic.
Wait...are you saying you ARE talking about the green indicator light below the high beams? That's just the headlight switch light...ie tells you when your headlights and/or marker lights are on:
Old February 3rd, 2016, 08:12 AM
Yes. That light come on to tell you the lights are on.
Old February 3rd, 2016, 08:54 AM
CDeWan
Clay DeWan
5.3L beastie
ahhhh.....
O.K. so my NAS 94 does have a burnt out bulb in that space. As that is my base line to compared then I know what is the problem.
thanks guys - problem resolved.
Old February 3rd, 2016, 09:45 AM
I scanned the warning light pages from my non-NAS owner's manual.
File Type: pdf Defender_Owner_Manual_Indicator_Panel.pdf (537.5 KB, 36 views)
Old February 3rd, 2016, 10:39 AM
roverman2010
1985 LR 90 200Tdi
So I take number 9 is not the window open indictor. LMFAO
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
Old February 3rd, 2016, 12:41 PM
CDeWan
Clay DeWan
5.3L beastie
So #7 Low fuel really works? on NAS vehicles?
------ Follow up post added February 3rd, 2016 12:41 PM ------
So #7 Low Fuel really works? On NAS trucks?
Old February 3rd, 2016, 12:55 PM
My recollection is that they removed the low
Fuel warning in 1994 when the 300tdi changes came in. I had thought the warning panel layout changed too. Never really looked too deeply myself.
Old February 3rd, 2016, 06:24 PM
There are different versions through the years.
Old February 3rd, 2016, 06:41 PM
Was brought up before and I had my dash open so figured I would take a photo of the magic mystery low fuel warning module that are in some? pre-94 trucks... It is taped up inside the loom and does not show on any parts diagrams... The wiring diagrams do not show it. Some show direct light connection to the sender.
ID:	141286   Click image for larger version
brake, ht
LED third brake light. Crash303 Smaller Projects 15 October 26th, 2016 10:11 PM
LED Indicator set with LED license plate light & Savage Defender For Sale - Parts 2 September 8th, 2015 05:25 PM
LED running light bulbs JBfoot Defender Technical Discussions 23 April 12th, 2008 05:53 PM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
Left rear brake Light Out, and I mean Out! RickM Defender Technical Discussions 6 December 8th, 2004 09:31 PM
