LED auxiliary lighting - Page 3 - Defender Source
Old May 22nd, 2013, 10:46 AM
mightymg's Avatar
mightymg
Lane Farka
97 D90, 05 LR3, 95 RRC LWB
My Rigid! I love it.. It is absolutley BLINDING!!
ID:	72850   Click image for larger version
project whore!
95 RRC LWB-- DD
97 D90 37 " krawlers, coilovers, beadlocks, stretched
05 LR3 - Mamas/ tow rig
- Moab rally vids 2010
Old May 22nd, 2013, 02:28 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Here's my install. I had tabs welded to the ARB underneath the top bar to mount the 30" Rigid LED bar. I mounted the 50" underneath the front of the Front Runner rack. Both positions where chosen for optimal light source placement and to keep them tucked in and protected. I added light covers to protect them when not in use and also to make them less noticeable and not attract more attention than necessary. Another benefit of the Single Row LED bar (compared to old Hellas) is that there is increased airflow to radiator in addition to improved lighting and draw.
ID:	72886   Click image for larger version
ID:	72888   Click image for larger version
Old May 23rd, 2013, 01:01 PM
myoverlandrover's Avatar
myoverlandrover
josh
109
You mind posting a picture from the front? I'm looking at light bars to mount on an inbound p&p cage but don't want it to stick out on the sides to much leaving it vulnerable to trees wheeling.
Defender 110
Old May 23rd, 2013, 01:04 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Which one do you want a picture of?
Old May 23rd, 2013, 01:16 PM
myoverlandrover
josh
109
Top 50" bar please
Defender 110
Old May 26th, 2013, 05:18 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
Josh,
I took a photo but I don't know if it will be of much help to you because the bar sits further back than the cage top bar. What are you trying to find out exactly? If you plan to mount it to a roll cage I would get a 40" bar not a 50".
Old May 26th, 2013, 06:29 PM
myoverlandrover
josh
109
Thanks for following up, what you said helps. I'm waiting on a cage and trying to plan on a led light bar but undecided with Wether to use one large bar, a few small ones or one medium in the middle and two smalls on the side. Within all that is how large overall to go to keep it protected within the width of the cage.
Defender 110
Old May 26th, 2013, 10:25 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
You might find your answer on this other thread. Another member posted pictures of his 50" bar mounted to a NAS 110 cage here but my 50" bar would not fit on my NAS 90 cage as you can see here.
Old May 28th, 2013, 01:39 AM
Backstay
John Hilton
1994 D90
I just received a new shipment of led light bars and work lamps if anyone is looking for a deal. From 2" to 40" width. Also a variety of work lamps. Can email details if interested. Received some billet tube mounts but haven't had a chance to see if they'll work on the NAS cage. Will try to check tomorrow.
Old May 28th, 2013, 06:45 AM
myoverlandrover
josh
109
What brand?
Defender 110
Old May 28th, 2013, 03:01 PM
Backstay
John Hilton
1994 D90
same as VisionX. www.visionxwholesale.com but call me if you want 800 665-5031 ask for John
ht
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
Packing the Hub bearings sflash868 Defender Technical Discussions 11 May 22nd, 2008 03:32 PM
ECR LED Group-Buy JimC The Vendors Loft 63 January 17th, 2007 04:53 PM
LED replacements: class 101 input discussion pls paulb Misc. Chit-Chat 7 March 18th, 2005 05:15 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
