Learn me on lift up door latches - Defender Source
Old January 3rd, 2015, 12:07 AM
toad's Avatar
toad
Cutter
I've posted a wanted add for a LH door latch as mine has stopped working, but I'm realizing that my style latch is different than anything I can find online. My '86 110 is Austrian if that makes any difference (I've seen specific parts for the German market in the parts catalog). The latch mechanism I've removed looks like the attached image, has a remote arm for the inner handle that appears to be permanently attached.
I've found a latch with Part No. MUC1035 but it looks quite different, enough that I don't think it will work as the striker doesn't appear to be the same. This eBay listing is for one
There are a few MUC 10** latches but none I have found images of seem to match my truck's style. I may drill out the rivets on my latch but not sure I'll be able to repair whatever is amiss within.
I'm fine swapping out the latch for a different mechanism, I just don't have a part catalog for lift latch style doors so I can't figure out what to hunt down. And of course if you happen to have a latch like mine you are willing to part with I'd be happy to compensate. Nothing like having your truck on the road after 7+ months of work only to have this break 4 days in.
Old January 3rd, 2015, 12:08 PM
toad's Avatar
toad
Cutter
For what its worth, found this after plenty of time on google: http://www.landroverworkshop.com/dia...aa270226_52672
MUC2290 and MUC6890, both NLA.
Old January 3rd, 2015, 12:54 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
Those appear to be exactly the same as my 84 uk spec. Which as you found out are NLA. I have acquired a set of push button doors and hardware to make the switch. I do not plan on selling my doors or hardware as I would like to try and restore the door frames and put them back on someday. Good luck in your search.
Ryan
84 110SW County LHD
07 L322 Vogue
Old January 3rd, 2015, 04:15 PM
johan's Avatar
johan
johan
2009 Range Rover
To me it looks like the one you found on ebay (MUC1035) are from an early 110, sliding windows. The door locks are different for this model.
According to my parts manual and your VIN, you need the MUC2291.
Just checked my pile of parts; I have two RH laying here. I don't know what is wrong with yours but maybe you can use parts from a RH to fix your LH ??
Johan
Old January 3rd, 2015, 06:24 PM
toad's Avatar
toad
Cutter
Johan yes mcu2290-2291 are the parts, superseded by mcu6890. Thank you for the offer, let me drill mine apart and see what is wrong. I know at the minimum the main spring is broken as the latch has no resistance. If it looks interchangeable between LH and RH I'll take you up on the offer. I may have a lead on a salvage from David at Urban.
door, door latch
Ex MOD door latches slacker Defender Technical Discussions 12 November 30th, 2014 12:04 AM
Front Door cards latches and strikers jjstahl3 For Sale - Parts 3 June 1st, 2012 01:31 PM
NAS Front Door Latches jjstahl3 Wanted 0 February 29th, 2012 03:03 PM
Door latches James Pierce Wanted 0 November 24th, 2010 05:14 PM
ST door latches, left and right Abrooks Wanted 3 July 11th, 2009 06:04 PM
