Leaning towards the driver side - Defender Source
Old November 16th, 2009, 12:33 PM
nmc
Noel Corpus
1997 Defender 90 LE
I recently replaced my springs with the standard OME 751/764 set up and my vehicle is leaning towards the drivers side. I half expected it to lean towards the passenger side based on older posts that I have read. Just curious as to how many have changed out there trailing arms after replacing their old spring/shock setup with the OME spring/shock set up to compensate for the lift. Is it possible that the drivers side trailing arm might be causing the drivers side lean or is the 2inch lift not enough cause this lean. It also looks like the rear anti roll bar bushings has crapped out where it connects with the anti roll bar joint (drivers side). Thanks for the help.
Noel
Old November 16th, 2009, 12:41 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Spacer under the drivers side springs will fix it easy
Jimmy Buffett
Old November 16th, 2009, 03:06 PM
i put the tall spring on one side in the rear and on the other side in the front.
Old November 16th, 2009, 08:08 PM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
gain weight
Driver side door handle mightymg Wanted 0 November 8th, 2009 09:55 PM
Excessive heat in driver side foot well Chris Vitale Defender Technical Discussions 14 August 23rd, 2008 01:03 AM
Driver side interior door panel needed Spleen Wanted 0 April 21st, 2008 12:48 PM
Plastic parts from driver side window?? Vadim Defender Technical Discussions 1 January 18th, 2005 03:06 AM
Driver side mirror jracenstein Defender Technical Discussions 3 October 22nd, 2004 10:00 PM
