Leaky Windshield? - Defender Source
Old October 12th, 2009, 04:15 PM
akfisher
robert hall
95 d-90sw
Leaky Windshield?
Was gone for a week and went to drive the d-90 and found standing water in the shelf under the dash on the passenger side that was then draining down onto the floor mat. the vehicle has sat out in the rain before and i've never this before. recently had the d-90 serviced by the local dealer and had them install a new heated windshield. took a quick look but didnt see an obvious source of the leak. this is a dumb question but could a poorly sealed windshield leak just from rain while the vehicle is sitting?
Old October 12th, 2009, 04:26 PM
Not likely your windshield, more likely its your scuttle vents. Sometimes these aren't closed, but sometimes they just leak anyway. New seals will probably take care of it as long as the thing close all the way.
Old October 13th, 2009, 12:55 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I have a leak somewhere below the windscreen as well. I suspect its the scuttle vent seals. It only leaks in a downpour and the water comes out on the top of the toe box where the pedals are. Is the scuttle vents the only option here or are there other areas where the bulkhead meets the hood where it can potentially leak?
Old October 13th, 2009, 01:02 PM
Options include the windshield (unlikely), the seal between windshield and bulkhead (unlikely without rust holes), the seal from the top to the windshield frame (if the sealant has come out and wate is forced in while driving), and the scuttle vents. Some bulkheads rust through in that area and leak too, but that's pretty advanced decay unless you're talking about a NAS 110. Search here for the "Water Ingress Manual" - its pretty helpful and it has diagrams.
Old October 13th, 2009, 04:47 PM
bjf's Avatar
bjf
barry f
94 ST #395
Upgrade vent seals to the rubber ones. Uses 3m caulk on clutch area
Old October 11th, 2010, 03:57 PM
cabell's Avatar
cabell
Cabell Crowther
Why can't I find the "Water Ingress Manual"?
Old October 11th, 2010, 04:06 PM
I just searched for "Water Ingress Manual" and came up with this thread, but the site it links to is down. will email you a copy I have.
http://www.defendersource.com/forum/...Ingress+Manual
Old October 11th, 2010, 04:16 PM
cabell's Avatar
cabell
Cabell Crowther
Thanks Charles. I swear I searched!
Old October 11th, 2010, 09:20 PM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
It was the air vent seals that caused my leak. They were old and falling apart. I haven't had a problem since I replaces them.
Old November 3rd, 2010, 09:35 AM
jhobbs
Jay Hobbs
1995 D-90 SW LRNA/10 (**sold**)
Anyone have a saved copy of the water ingress .pdf? I thought I did but can't find it and the link above doesn't work anymore.
Old November 3rd, 2010, 09:37 AM
Attached
Old November 3rd, 2010, 09:40 AM
jhobbs
Jay Hobbs
Old November 3rd, 2010, 11:43 AM
My 90 had a leak from a failure of the seam sealer where the bonnet drip channel is attached to the bulkhead. That water ran down the bonnet (parked facing slightly uphill) and went behind the drip channel. From there it ran down the bulkhead to a place where the seam overlaps the wrong way and the water rand down into the fusebox and filled the turn signal/hazard flasher relay with water. I got in the truck and found the trailer warning light on the dash was illuminated. Took awhile to figure out but was definitely surprised when I pulled the flasher apart and it dumped a thimble worth of water on me. Dried it out and it is still working...
Old November 3rd, 2010, 12:23 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
On my '97 SW, my leak was between the windshield frame and the top of the bulkhead. Was a unique foot washing feature I thought at first, but I couldn't find the switch to operate it when it wasn't raining.
Dennis
Old November 3rd, 2010, 02:03 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
I had a leak on the Driver's doorseal, it had detached from the frame, a drop of silicone to hold it back in place and duct-taped it there for 3 hours to let it set and it's been fine for a few months. (specifically pages 11 and 12 of the pdf Charles attached above)
My biggest leak was the sunroof... which I was finally able to "seal" using vaseline on the gasket
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 4th, 2010, 01:58 AM
DefenderPilot
George
1997 D90 SW
Originally Posted by cgalpin View Post
Attached
Thanks for posting this but where do you buy this dum dum and dum dum strips? Sounds funny. Thanks
------ Follow up post added November 3rd, 2010 11:00 PM ------
Do all new seals come in rubber now and are these for the vents on the fire wall that open from the inside handle on either side?
Old November 4th, 2010, 04:06 AM
dum dum is 3M Strip Caulk, its not hard to find.
Old November 4th, 2010, 11:02 AM
jhobbs
Jay Hobbs
It more than likely won't be on the shelf out front. Try an auto store that caters to paint and body repair. O'Reilly or Napa should have it.
Old November 4th, 2010, 11:21 AM
Eastwood is great for stuff like this
http://www.eastwood.com/3m-flexible-...ulk-20-yd.html
uk windshield frame vs. nas d90? steved90 Defender Technical Discussions 3 April 5th, 2005 09:07 AM
windshield frame steved90 Wanted 2 March 21st, 2005 11:27 AM
Heated front windshield for D-90? blenkush Defender Technical Discussions 5 February 28th, 2005 09:53 PM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
Heated windshield TDI Guy Misc. Chit-Chat 15 November 11th, 2003 05:42 PM
