Leaky windows - 97 D-90SW - Defender Source
Old April 1st, 2004, 06:12 PM
BarryO
Barry O'Mahony
97 D-90 SW LE
This winter was tough on the D-90. It appeared that alot of water got in through the side rear windows, and the humidity got high enough that mildew formed inside on some surfaces.
I'm not sure what's causing the leaking; perhaps the felt-type weatherstripping around the movalbe panes are worn out. Any suggestions?
Old April 1st, 2004, 07:41 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Barry,
When I was looking for a leak in the front, the best advice I got was to wait till night fall. Using a small maglight investigate the rear windows. If your buddy can see light on the outside or vice versa, water is getting in. I used a marine grade sealant where my seals had failed, as it was only in one spot and the rest of the seal looked in good condition. Hopefully you can determine at least where the leak is and how to potentially seal it, either with replacement parts or with a sealer.
EwS
Old April 1st, 2004, 08:17 PM
kellymoe's Avatar
kellymoe
kevin
defender 130
My truck leaks so bad I ended up drilling a fe holes in the floor. At least I don't have standing water anymore. Funny we are discussing this now. It is pouring rain in Burbank California right now as I type.
Old April 2nd, 2004, 03:28 AM
ahit man I got a 95 wagon. it leaks, I had thought thru the rear windows which isnt a bad idea but my front leaks bad, thru the front vent's under the window's I just cover it with one of those blue tarps when the forcast calls for rain otherwise she is wide open..... just a thought, the 15 dollar blue tarp is good insurance against waterdamage/rust
Old April 2nd, 2004, 01:12 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Ah jeeezz Phil....a tarp!
You could probably fix that by either replacing the seals or the vent handle. The new handle might provide a tighter seal on the vent for you. Of course, RDS is a good place to get these items. Just my 0.02
DJ
Old April 2nd, 2004, 01:52 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
The tech section has that really cool article on replacing your seals with those from a Series RIg which are much better.....
That would be cool Phil...
Old April 2nd, 2004, 07:39 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
I just put the rubber seals around my vent openings. No more leaks.
Rovers North is out of them and says they are being discontinued. I don't know if that means they are just not carrying them anymore, or if nobody makes them anymore.
RDS had them in stock just a few weeks ago.
I used silicon sealant instead of glue. It is somewhat adhesive and is a better sealant than the glue.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
90, 97, d-90, window, windows
ST windows slide Cyborg Defender Technical Discussions 3 May 10th, 2004 12:50 PM
Windows for a 97 Softtop jbird Wanted 5 April 30th, 2004 02:25 AM
More Softtop Help - 97' Windows jbird Defender Technical Discussions 2 April 27th, 2004 11:39 PM
Power Windows (was: Leccy Windows!!!!!) P1CR Defender Technical Discussions 21 February 28th, 2004 01:14 PM
Door Windows on '97 D90 Rob Defender Technical Discussions 4 November 3rd, 2003 04:11 PM
