Leaky power steering box - Defender Source
Old January 22nd, 2009, 03:28 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
The other day, I power washed the underside of the defender to try and get the road salt off and ever since then, my power steering box has been leaking fluid. It seems to be leaking where the steering arm connects to the box. Could this be fixed with a new seal kit? If so, how easy is it. (I'm not very mechanically inclined but am trying)(( Just replaced the fuel filter today and am very pleased with my work.))
Also, are any special tools needed. I do have the workshop manual from RN for starters.
Eric
[QUOTE=Lindy]The other day, I power washed the underside of the defender to try and get the road salt off and ever since then, my power steering box has been leaking fluid. It seems to be leaking where the steering arm connects to the box. Could this be fixed with a new seal kit? If so, how easy is it. (I'm not very mechanically inclined but am trying)(( Just replaced the fuel filter today and am very pleased with my work.))
Eric[/QUOTE
One more thing, In the past 10 days, I have added two containers of Lucas power steering stop leak and about a quart of PS fluid but haven't seen much change.
Old January 22nd, 2009, 04:49 PM
Buy a meridian reman. The seal is a temp fix as meridian permantly fixes the problem by replacing the bush that wears and causes leaks with a bearing.
I sold a lot of these, and none came back. I, on the other hand, live with a leaking box. YMMV
Old January 22nd, 2009, 04:54 PM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
What is a meridian reman and where would I find one of these?
Old January 22nd, 2009, 05:04 PM
I posted the website a couple days ago. Search for steering box leaking.
http://www.defendersource.com/forum/...ad.php?t=18466
Old January 22nd, 2009, 05:12 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
How much do those run? My range rover's is leaking.
Old January 22nd, 2009, 05:15 PM
They used to be $300 or so, but Meridian had issues with getting enough cores. Someone needs to call over and see if they still sell them. I bet mike at LR westchester would stock them if meridian would sell them.
Old January 22nd, 2009, 05:16 PM
cellulararrest
Chris Snyder
Cool that's not bad at all. If anyone finds out if they're still available let us know . I'm in no rush just would be nice to know there's a good fix out there.
Old January 23rd, 2009, 09:31 AM
Lindy's Avatar
Lindy
Eric Lindstrom
1994 d-90 #1444
Thanks for the help guys. I've talked to meridian and their price is $295 plus $160 core charge.
Looks like this is the way I'm going.
Old January 23rd, 2009, 10:35 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
I put a Meridian rebuild in the 110 over two years ago. Still leak free and cheaper than OEM (which would probably be leaking by now )
Chance
Old January 24th, 2009, 12:34 AM
I guess I should break down and order one for the LWB. It has been leaking for 6 years.
JRW's Avatar
JRW
94 D90 ST #1247
Eric ~ If you replace it yourself, please take pity on those of us who will have to do it in the near future and post the steps/pictures...
Old January 24th, 2009, 07:54 AM
pushngo
Randy Williams
I have one here $350 + your core
Paypal is usedroverparts@yahoo.com
Old January 24th, 2009, 04:20 PM
Do any of you have a source for the power steering pump?
Old January 24th, 2009, 04:58 PM
pushngo
Randy Williams
Put on a Chevy one NAPA # 20874 for an '88+ S10 4 cyl $100 and way better pressure than the OEM Rover
Old January 24th, 2009, 05:58 PM
Is that right. might have to pick one up.
Old January 26th, 2009, 04:31 PM
pushngo
Randy Williams
The output flange is straight instead of the bend like on a Rover so you may have to shorten or lengthen your return line but it is not a difficult job.. once you get the hub off your old pump. Have a good puller onhand.
Steering box adjustment, backlash, drag link ?s... wicks Defender Technical Discussions 27 May 28th, 2014 02:05 AM
Leaky Steering Box RyanS Defender Technical Discussions 19 April 11th, 2009 10:48 PM
RHD Power Steering Box.. TDI Guy For Sale - Parts 5 February 7th, 2006 10:42 AM
