Leaky fuel tank - advice? - Defender Source
Old May 17th, 2015, 02:24 PM
GRNWOLF's Avatar
GRNWOLF
1985 Defender ex MOD OM617
Woke up to a wet spot in the driveway. Fuel dripping off the tank. I hadn't driven in a few days so I thought this was odd.
Before I make things worse, for those of you that have encountered this, what is the proper course of action?Click image for larger version
GRNWOLF
1985 Defender 110 ex MOD Wolf Tithonus; OM617
Phoenix, AZ
Old May 17th, 2015, 02:39 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Well, at least no one tried to steal fuel although a puncture would be easier to find. Have you found it? Steel tank on the ex-mods, right? If you can't find it, you might be able to pressurize the tank in place by plugging the relief valve. Otherwise, I'd drain it, drop it and pressure test it to find the leak. As a semi-permanent and cheap band-aid, my mech used metal epoxy on a fuel theft puncture for a friend that didn't want to replace the tank and it worked like a charm. But this could be a great excuse to install a clean new plastic one and a nice skid plate cradle.
Old May 17th, 2015, 05:07 PM
rankar's Avatar
rankar
97 SW #2236 (Maggie)
That metal epoxy held?
Old May 17th, 2015, 07:00 PM
D90Overkill
David Frank
1995 ST #2615
To this day.
Old May 17th, 2015, 08:16 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Or you can get some PRC and patch the thing forever. We use that to seal wet wings (wings inside as a fuel cell). It resist almost everything from gas, fuel and oil. It's the same method as JB Weld. Two part but I recommend weighting the parts if it's PRC.
Old May 20th, 2015, 12:11 AM
GRNWOLF's Avatar
GRNWOLF
What's PRC?
GRNWOLF
Phoenix, AZ
Old May 20th, 2015, 12:44 AM
Werrea's Avatar
Werrea
Anthony Werre
08 LR3
Mine was leaking. Turned out it severely rusted between skid plate and tank. Beyond repair. New large capacity tank solved the problem.
Old May 20th, 2015, 01:17 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
http://www.vansairforce.net/articles/tank_sealant.pdf
------ Follow up post added May 20th, 2015 01:17 AM ------
Gives you an ideal.
Old May 20th, 2015, 11:22 AM
GRNWOLF's Avatar
GRNWOLF
Thanks CDNRover I'll probably go that route. Looking up tank prices had me imagining, in horror, all my planned projects/upgrades going away.
GRNWOLF
Phoenix, AZ
Old May 20th, 2015, 12:09 PM
D90Overkill
David Frank
1995 ST #2615
Did you find the leak?
Old May 20th, 2015, 02:12 PM
GRNWOLF's Avatar
GRNWOLF
Its been a busy week so I haven't pulled the tank yet. I crawled around underneath and it appears to be coming from the top forward of the tank...the one spot I can't see or reach. From there it leaks out to the bottom forward corners.
GRNWOLF
Phoenix, AZ
Old May 20th, 2015, 03:07 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
After you drop the tank down, you'll be able to see the leak and if it's worth fixing.
I typically replace a leaking tank with a new one.
The process I follow is to drain the tank, drop it as close to empty as I can get it.
Then fill it again when out if needed to further examine the leak.
Typically, there is no need to refill the tank because it ends up on the scrap metal pile when a new one goes in.
RDavisinVA
Old May 20th, 2015, 03:29 PM
Tanks are like $300 new, right?
Old May 20th, 2015, 04:06 PM
GRNWOLF's Avatar
GRNWOLF
Metal tanks are.
GRNWOLF
Phoenix, AZ
Old May 21st, 2015, 12:04 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
Plastic is really expensive? Take for account that they should last longer then the car!
Old May 21st, 2015, 12:25 AM
GRNWOLF's Avatar
GRNWOLF
The prices I saw were significantly more expensive, $1000+. I'm still trying to figure out why
GRNWOLF
Phoenix, AZ
Old May 21st, 2015, 12:34 AM
D90Overkill
David Frank
1995 ST #2615
If you were going to replace it, I imagine that you could drop it, use it as a template, and have a superior one fabbed up (using alloy) for less than $1k!
Old May 21st, 2015, 06:54 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
1k is what the dealer ask for a metal fuel tank on my 110. Bought it from Trevor for a 1/4 of that price! That means I can afford to swap it 4 times before even being square!
Have one fab at that price! You can even have a heated one for wvo for that kinda dough..
Old May 21st, 2015, 02:18 PM
GRNWOLF's Avatar
GRNWOLF
Yeah the plastic ones were too expensive and you're right I could get it gold plated at that price. I'm going to pull the tank this weekend. My fingers are crossed for a simple repair. I really want to spend that money on a canvas
GRNWOLF
Phoenix, AZ
Old May 21st, 2015, 02:46 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Is your plastic tank similar to a Disco or RR classic enough to substitute?
RDavisinVA
advice, fuel, fuel tank
Advice on how to get 2nd fuel tank filler location to look stock. D90Overkill Defender Technical Discussions 29 May 16th, 2016 08:39 PM
Leaky Fuel Tank mgyip Series Technical Discussions 14 July 3rd, 2013 10:31 AM
advice on replacing fuel tank. CavemanDiesel Defender Technical Discussions 3 June 7th, 2013 11:04 AM
Diesel fuel tank vs. Gas tank Tyler Wirken Defender Technical Discussions 9 January 28th, 2010 07:25 AM
Leaky Fuel Tank cbass Defender Technical Discussions 12 June 2nd, 2005 04:50 PM
