Leaky Caliper Question - Defender Source
Old February 16th, 2011, 06:28 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
My front right caliper has been leaking slowly for a while which I think is the source of my truck pulling hard to left when i slam on the brakes. Now I've noticed the rear left caliper is leaking a bit worse than the front. Im planning on replacing all the calipers, but I am wondering if they are related or its just coincidence. The truck has 150K on it so I figure the Master is getting close to going since everything else is!
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old February 16th, 2011, 07:02 PM
Probably related in the sense that water in the brake fluid will corrode all calipers and/or salt/rust etc effects them all at about the same time, but not related in the true sense of one failing caused the next.
roverguy had a good deal on D90 front brake packages (calipers/rotors/pads). Someone posted a link to closeout MCs for $67 each at rock auto or something like that.
Old February 17th, 2011, 03:38 PM
waveridin1959
Brian Jones
1995 D-90 ST #2892
I'll go ahead an replace the Master Cylinder if they are not to expensive. I was just making sure there wasn't something weird I was missing before I replaced everything. I've already replaced the line with braided. Is there anything else I should think to replace beside the calipers and master while i'm at it? The rotors are is good shape.
1995 Defender ST
1996 Discovery SE7
Old February 17th, 2011, 03:58 PM
Other than pads and pad hardware, any hard lines that look like they have rust issues. Check the ones on the rear axle and the one going from the distribution valve to the t-piece on the rear axle where it is close to the frame.
front caliper brakeline jabber Defender Technical Discussions 5 May 3rd, 2009 11:31 AM
Caliper Question fleabus Defender Technical Discussions 4 February 2nd, 2009 06:08 PM
Range Rover Front Brake Caliper Question TDI Guy Misc. Chit-Chat 10 May 24th, 2006 08:14 PM
Rear brake caliper leak cgalpin Defender Technical Discussions 11 July 8th, 2005 11:56 AM
